charlie Offline
#1 Posted : Thursday, 24 September 2009 2:34:58 AM(UTC)
charlie
Are the hk gts monaro bonnets different from say a hk sedan?????
Meaning the gts badge holes????
I know the hg ht are different from the scoops.
vintageholden Offline
#2 Posted : Thursday, 24 September 2009 3:52:37 AM(UTC)
vintageholden
i dont think so
pretty sure there the same
kingswood and monaro
http://cgi.ebay.com.au/H...a52&_trksid=p3286.c0.m14
Edited by user Thursday, 24 September 2009 3:56:23 AM(UTC)  | Reason: Not specified
#3 Posted : Thursday, 24 September 2009 4:31:22 AM(UTC)
HK are the same basically, except for badge and accessory holes.
HT Monaro bonnets are also the same as the rest of the range, just like HK range. HT has H-O-L-D-E-N holes across the nose. GTS have flutes.
HG same story, ie basically the same bonnet across the range, GTS has flutes. HG have slots on teh passengers side for the badge.
charlie Offline
#4 Posted : Thursday, 24 September 2009 6:08:56 AM(UTC)
charlie
What im getting at is, if i had a hk gts bonnet would it sell as a hk gts bonnet with the gts badge in there.
Or would it just sell as a normal bonnet sedan wagon ute ??????
like a holden monaro badge for the hk that goes in the grill, they are different to a holden badge for a sedan becouse of the pin holes, and will fetch about 100 bucks more that a normal one.
#5 Posted : Thursday, 24 September 2009 6:25:47 AM(UTC)
Itd just be a HK bonnet with holes for a badge, no such thing as a HK GTS bonnet.
Not sure what you mean with grille badges. HK Monaro grille HOLDEN badge is the same badge as Belmont and Kingswood sedan, wagon and ute. Only GTS, Premier and Brougham are different with GTS being different to Premier/Brougham.
charlie Offline
#6 Posted : Thursday, 24 September 2009 4:31:48 PM(UTC)
charlie
The HOLDEN badge in the grille of a hk monaro has one of the pins off set to fit in the grille as the grille are only for the gts monaro.
So yes they r different to a sedan wagon or ute HOLDEN badge.
I had 2 here the monaro one and the sedan one sold the monaro one for $210 bucks and the sedan one for $22 bucks.
#7 Posted : Friday, 25 September 2009 3:06:52 AM(UTC)
There are two grilles in HK (variations of each with paint). Two headlights and 4 headlights.
There are three HOLDEN badges in these grills, one for 4 headlight, ie Premier Brougham, and two badges for two headlights, ie Belmont, Kingswood and Monaro. The two badges for Belmont, Kingswood and Monaro are, one for GTS and one for all others.
Warren
#8 Posted : Friday, 25 September 2009 3:29:14 AM(UTC)
As I stated above and Warren also confirmed, HK Monaro grille badge is the same as Belmont and Kingswood, and uses the same grille. HK GTS also uses the same grille bud the badge is different in that it has raised edges around the letters and its painted red, pins are the same though. I think you are confusing these with Premier/Brougham which have a different pin arrangement to the rest.
charlie Offline
#9 Posted : Friday, 25 September 2009 4:49:47 AM(UTC)
charlie
I only say this, is, that i got picked up when i went to sell the HOLDEN badge that came from my gts hk.... I lined up the pins and it was different that the other HOLDEN badge.
I always thought the grille in the gts had a different placement for that badge.
I may be wrong, and wish i still had the photos of the badges side by side.
#10 Posted : Friday, 25 September 2009 5:19:58 AM(UTC)
wasnt it the hk grill badges from rarespares that had the pins in the wrong place? or am i confusing it with another badge? maybe charlie had a rarespares badge?
anonymous Offline
#11 Posted : Friday, 25 September 2009 6:20:49 AM(UTC)
anonymous
All Rare Spares badges have the pins in the wrong place.
If you have got a HK bonnet that is factory and is a GTS one ,
it will be different to Any other HK bonnet, as it will have the holes in the right place for the GTS badge ,
that is of course you use a GMH GTS badge.
80569K Offline
#12 Posted : Friday, 25 September 2009 6:33:12 AM(UTC)
80569K
I have bought this pin issue up before and to be fair to Rare Spares all the badges Ive seen for sale in Australia are wrong, which doesnt make it right though, does it!
Edited by user Friday, 25 September 2009 6:34:18 AM(UTC)  | Reason: Not specified
charlie Offline
#13 Posted : Friday, 25 September 2009 7:12:27 AM(UTC)
charlie
Thanks for that, i did think the gts badge holes where different from a sedan ect.
charlie Offline
#14 Posted : Friday, 25 September 2009 5:57:47 PM(UTC)
charlie
Cheers, i did think that.
#15 Posted : Friday, 25 September 2009 6:45:59 PM(UTC)
I think we need to clarrify things a bit better.
Firstly, on the grill badge, the 4 headlight grill badge and the GTS grill badge are the same raised edge with paint fill. The 4 headlight is white fill and has unique pin location and the GTS badge has red paint fill and same pin location as the flat HOLDEN badge.
The reason for the white badge having different pin location is probably to ensure that this was the only badge fitted to 4 headlight grills during pre production process. But this is just one theory.
The different pin location came to light when red fill badges became rare, people tried to repaint white ones, only to find they did not fit the 2 headlight grill.
On the bonnets, hole location does not make parts different, otherwise a V8 guard would be different to a 186 guard and a 161 guard would be different again. Same with Belmont, Kingswood and Monaro guards as the holes for these badges were different. You can take any HK bonnet and drill the holes for the GTS badge. (on the production line all the above are diferent, as the holes are punched before painting, so a Kingswood guard must go on a Kingswood, and if it is a V8 Kingswood it is a different guard to a 161 Kingswood)
HT and HG bonnets have different undersides, which can help identify manufacture period.
Warren
charlie Offline
#16 Posted : Saturday, 26 September 2009 1:14:09 AM(UTC)
charlie
Thanks warren
saying that, in your opinion, would you say, an origanal gts monaro bonnet, is far beter to have than say a belmont one thats been drilled to fit a gts badge?????
Or it wouldnt matter couse no one could tell???
#17 Posted : Saturday, 26 September 2009 2:02:50 AM(UTC)
Thanks warren
HI charlie.
As long as the badge holes were neatly drilled & then properly painted it wouldnt really matter much.
If youre comparing a GTS bonnet to a Belmont bonnet there is also the matter of the stainless moulding on the leading edge, which is not fitted to Belmonts. It is fitted to all others though. At the factory the moulding clips are retained by little T-headed studs which are welded on prior to painting. These are much better than aftermarket pop-rivets or screws, which never seem to be fitted in the correct position.
#18 Posted : Saturday, 26 September 2009 4:00:41 AM(UTC)
Well it really is not a matter of opinion, if you take a HK Kingswood/Monaro/Premier/Brougham bonnet and drill three holes in the right place it would be impossible for anyone to tell that it was not a GTS bonnet. Simply this is what GM-H did in the factory.
This was in fact an after thought, the GTS badge was to be fitted to the grill, so this is probably why the red fill Holden badge has been a problem.
Warren
charlie Offline
#19 Posted : Saturday, 26 September 2009 4:29:08 AM(UTC)
charlie
Only reason i am enquiring as i have the hk bonnet on my hg, soon i will be putting this on, but have to paint it first, then i have the bonnet, which started its life on a hk gts 186s monaro,sitting around doing nothing, its painted in the comaro gold you see in my photo.
But knowing where its from and having owned it for 19 years i would rather it to some one looking for the real deal.
cheers again for the help.
#20 Posted : Saturday, 26 September 2009 4:36:05 AM(UTC)
If its in good nick it will sell well anyway, so list what it came off on an Ebay ad. Only hassle is if you are in an out of the way place it might not sell for much. Near a metropolitan area and you might get a nice earn.
Guest (5)
This page was generated in 0.082 seconds.
