hkute68 Offline
#1 Posted : Saturday, 26 September 2009 11:38:25 PM(UTC)
hkute68
i just looked at what appears to be a factory V8 hk ute, but not sure if the motor is the original, i have some numbers which i hope will help me.
vin 80380khs38800
fire wall hk31970s with a extra (s) below
engine k10 18
ss119 stamped in a odd manner.
vehicle is very rusty, anybody have an idea on value,looks to be all there.
thanks in advance.
#2 Posted : Sunday, 27 September 2009 3:12:42 AM(UTC)
Was thanked: 604 time(s) in 571 post(s)
HK do not distinguish between 6cyl and V8 on ID plates. That is a Pagewood built Kingswood ute. That engine number isnt originally from a Holden or GMH vehicle. To be orignal its be something like 30714123K1018 (approximate only and ive used your Mckinnon engine numbers to show you how it looks). The 30714123 (or whatever the 14123 is) is in a larger font to to the K1018.
The only way youd pick it as a V8 would be by the speedo cable and where it enters the cabin, however this can lead you astray as 6cyl 4spd HK utes had "V8" box and hence speedo cable.
hkute68 Offline
#3 Posted : Sunday, 27 September 2009 4:10:58 AM(UTC)
hkute68
thanks hk 1837,thats the only numbers i could see on the front of the block though?
i am not familiar with these mckinnon numbers and how they work?
#4 Posted : Sunday, 27 September 2009 6:50:23 PM(UTC)
ask yourself this; 1/. does it have 2 doors? 2/. does it that a tray behind the seat?
if you answered yes to both questions, then there is a good chance its a utility.
hope this helps....
"We wreck = KNOWLEDGE" lolololol
hkute68 Offline
#5 Posted : Sunday, 27 September 2009 7:06:54 PM(UTC)
hkute68
thanks we wreck for your useless input,verbal diarrhea is one one of your strong points.
i am looking for a particular ute
#6 Posted : Sunday, 27 September 2009 7:21:22 PM(UTC)
but you did ask the question that required a good answer, so yanno? im a bit bored this morning, need some quality reading, oldholden.com doesnt do it for me, but fastlane does..
now you know why i have a pic of loo paper under my "5" stars..hahaha
buts its nice and soft paper as well...
#7 Posted : Sunday, 27 September 2009 7:30:33 PM(UTC)
K1018 just means McKinnon, Canada 18/10/??, ?? probably 1967 or 1968. This is stamped when the engine is completed, and GMH stamped the rest at the 5 x assembly plants. That engine isnt going to be an original GMH engine, so probably an import. It could be anything too. See if you can get the block cast number, behind the passengers side head bewteen the head and the gearbox on the sloped flat part.
hkute68 Offline
#8 Posted : Sunday, 27 September 2009 9:17:29 PM(UTC)
hkute68
thanks hk1837
i will see if i can get the owner to find that number.
what would ss119 mean then?
#9 Posted : Monday, 28 September 2009 12:45:17 AM(UTC)
No idea.
