69HT_MUNRO Offline
#1 Posted : Monday, 28 September 2009 7:48:25 AM(UTC)
69HT_MUNRO
Does anyone know what size bores a 179HP would have had from standard?? Also what would a block with all its bits n pieces + spares be worth?
Cheers Stephen
Be careful about reading health books. You may die of a misprint.
[email protected]
http://gallery.oldholden.com/69HT_MUNRO/
[email protected]
#2 Posted : Monday, 28 September 2009 9:03:19 AM(UTC)
The standard bore size for a 179 Holden 6 is 3 9/16" or 3.5625".
The HP is meaningless, they have the same size bore dimension, with or without the HP.
69HT_MUNRO Offline
#3 Posted : Monday, 28 September 2009 9:08:19 AM(UTC)
69HT_MUNRO
Yeah I wasnt totally sure, doesnt HP define an early block??
Cheers Stephen
[email protected]
[email protected]
#4 Posted : Monday, 28 September 2009 4:23:28 PM(UTC)
Yes, all EH 179 blocks to late 1964 had HP cast into the side, but they were no different in any other way to those cast 179.
adam PERTH Offline
#5 Posted : Monday, 28 September 2009 6:48:48 PM(UTC)
adam PERTH
a good way to tell if its std bore or close to it, at swap meets and random finds is the colour of the rod and main bearings, the original ones were a copper colour.
Handy when its a basketcase motor..which it sounds like it is..
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
65ehpv Offline
#6 Posted : Monday, 28 September 2009 8:54:18 PM(UTC)
65ehpv
Im fairly certain that HP blocks were used in Premiers as they were mainly automatics whilst the other 179s were in the specials etc
and just confirming the details, bore 3.563in, stroke 3.00in, output 115bhp @ 4000rpm and torque 175ft/lbs @ 1600rpm
Carpe Diem
Carpe Diem
adam PERTH Offline
#7 Posted : Monday, 28 September 2009 9:38:33 PM(UTC)
adam PERTH
not quite,
the EH ran the HP, in all Hydromatic cars and some manual ones too.
yes, all premiers were 179 HP standard, and 95% autos.
i have only seen several 235M and 239M bodied cars, so manual premiers were rare.
The HP was an option for the EH, and often seen in specials, auto or manual,
however the "HP" is rare in base models sedan ute van.
most of these were 149.
not sure of the exact changeover, but the HD ran the 179, not HP
WANTED:
65ehpv Offline
#8 Posted : Monday, 28 September 2009 9:59:08 PM(UTC)
65ehpv
Cheers Adam, always happy to be corrected
Carpe Diem
Carpe Diem
#9 Posted : Monday, 28 September 2009 10:10:35 PM(UTC)
They changed from the HP to the 179 casting number around October 1964. So this would be the last 3 months production & also 65 EH utes & vans used the same block as the HD 179.
peter_flane Offline
#10 Posted : Tuesday, 29 September 2009 3:58:48 AM(UTC)
peter_flane
Early EHs did not have the option of a 179 on manual cars. The S4 was the start of the 179 manuals.
http://www.ehlimo.com.au/
adam PERTH Offline
#11 Posted : Tuesday, 29 September 2009 9:00:45 PM(UTC)
adam PERTH
did the Late EHs run the "M" prefix, or the "179" prefix
WANTED:
adam PERTH Offline
#12 Posted : Tuesday, 29 September 2009 9:04:06 PM(UTC)
adam PERTH
hi pete, when did the 179 manual appear.
adam
WANTED:
#13 Posted : Tuesday, 29 September 2009 10:00:30 PM(UTC)
To clarify several things.
1. The EH S4 was the first EH with a manual 179 but, these were a small run of Specials built in Sept 1963.
2. The first run of normal EH manual 179s werent built until around Feb 1964. After this date they were commonly available.
3. All EH 179 blocks, including those fitted to utes & van up to June 1965 had an M stamped engine number prefix. This is regardless of whether they had a 179 or HP cast on the side of the block.
4. The only engines with a 179 stamped engine number prefix were the HD 179 & X2 engines. These had the prefixes 179F & 179X respectively.
adam PERTH Offline
#14 Posted : Wednesday, 30 September 2009 2:12:24 AM(UTC)
adam PERTH
so, there must have been some 149 premiers made, i guess for anything upto feb 1964...is this true
WANTED:
#15 Posted : Wednesday, 30 September 2009 2:25:42 AM(UTC)
No, that is about the only variant that wasnt made.
Prior to Feb 64, if you wanted a Premier you got Hydra-Matic or nothing. All EH Premiers had the 179.
adam PERTH Offline
#16 Posted : Friday, 2 October 2009 4:06:49 AM(UTC)
adam PERTH
Yes, i always thought the EH prem was 179 only.
In the sales brochures, it says the 179 is standard equipment for EH Premiers.
was never 100% sure,
thanks
WANTED:
Fxxxrr Offline
#17 Posted : Wednesday, 26 February 2025 2:00:56 PM(UTC)
Fxxxrr
Originally Posted by: adam PERTH Go to Quoted Post
not quite,
WANTED:
My May 64 Van has the HP 179 in it from factory, Mind you it was built to be an Ambo from factory
and was ordered in fleet colour etc so possibly optioned with the HP at that stage
Guest (14)
This page was generated in 0.106 seconds.
