#1 Posted : Tuesday, 20 September 2005 6:26:21 AM(UTC)
I bought this car not concerned with what it was untill a freind reckoned it was a gtr . it is almost ready for painting after 10 months of body work as it previously had a9x flares and had had all the inner gaurds hacked out.
A freind advised to repair the gaurds was a big job and not to buy it but i bought it anyway.After buying found it had had a big hit in the right front and had been repaired hence the chassis straigtening
The Car has had every removable part replaced and is all sitting in my garage awaiting the body to come back from painting.
sorry photos are not in order still learning.Cannot take credit for all the metal work as a panel beater mate did a lot of it .The chassis on right side had to be pulled 18mm forward,and 15 mm down the right floor had to be pulled forward,both door pillars were replaced both sills were removed and refitted to match the gaurds,the right hand door edge was built up 5mm as the previous person had gound the door edge to allow the door to open.the right inner gaurd was also 5mm to short and had to have a peice put in.All the front end was brazed on so all that had to be removed and redone with mig the boot floor and body floors were hand made by the same panel beater mate as was the left and right lowwer rear sills.I would have given up long ago without the persistance of mates who said it could be done with a lot of time.
front gaurds hacked away
rear same
front gaurds repaired after body being bare metaled
rears in progress
rust in boot floor
one of the new peices fabricated for boot floor
new section fitted
chassis being straightened
front end removed to replace door pillars
eng to go in after painting
more engine
door pillar rust
front end back on
x member blasted highfilled and 2 packed
diff 2 packed
front end
wish bones
front end going together
brakes
ready
new rotors
ready to replace old with new front end
door pillar finished
sill done
new right rail fabricated and fitted
rust in door hinge area
body primed to get lines right
body now straight and all gaps in doors bonnet and boot etc within .001mm as is chassis
door finished
the only bog in the whole car
underbody being coated
rear finished
left rear
been a bit slack lately but now back into it also updated list of specs
engine specs as follows
202 plus 40thou
steel crank
xu1 hinged sump
hi vol oil pump
7500 rpm balancer
gilmer pulleys
hm headers now thermal coated
triple 45 mm webers polished
186 12 port head huge valves ported and polished
block releived to clear valves
head converted to run ulp
ballanced
starfire rods
acl 10.1 flattops
roller rockers
solid cam(bathurst xu1 spec)with roller followers
lightened flywheel
electronic ignition
3 core polished alloy radiator
approx $7000 in ealrs braid still to go on to
paint and body
body has now been file finished
Colour will be Gunmetal Metalic underbody and eng bay in 2 pack springs and shocks Anodise blue as are calipers and about 3500 in chrome bits and peices
Block has been deburred and 2 packed in GMH red
Body has had in excess of 350 manhrs spent on it and is going to be painted in 2 weeks
Interior
Retrimmed in original long grain with GTR embridered in headrests
new door trims and all glass replaced only parts on the entire car that have not been replaced are the 2 outer door handles all body panels repaired not replaced gaurds etc
full length console
new carpet and dash pads
Pioneer stereo and dvd
General
Every bolt on the car is Chrome allen headed bolts (only need 3 allen sockets to strip car)
Wiring being ran down inside of chassis rail no wiring will be seen
False stainless firewall
Left chassis rail to have 2 wiring plugs to suit 6 or v8 just plugin when ready
Chassis reinforcement kit
Hyrdralic clutch
greg m
Edited by user Wednesday, 13 December 2006 8:39:24 PM(UTC)  | Reason: Not specified
#2 Posted : Friday, 30 September 2005 10:20:21 PM(UTC)
Im assuming you got the link right for your photos, but for some reason i cannot see them... Is it the same for you? I would like to see your pics!! Sounds like you've put a lot of work into it!!
".....and it's 186 cubic inches.... AROUND"!!
#3 Posted : Friday, 30 September 2005 10:45:17 PM(UTC)
hsv484 if you want email me the images and i'll put them up on the FastLane Server
Fastlane Administrator
#4 Posted : Friday, 4 November 2005 3:36:07 AM(UTC)
U should have put an eight in it u,d have money left over after u got the conversion kit and put it through ADR,s compared to what uve lashed out on there with the six!!!But i,m sure that it sounds grouse it sure as hell looks it!!!
Munromad2004 Offline
#5 Posted : Friday, 4 November 2005 5:59:44 AM(UTC)
Munromad2004
Great work.
It's good to see a car as butchered as that one being lovingly restored.
Did you find out if it is in fact a GTR?
#6 Posted : Friday, 30 December 2005 4:22:58 AM(UTC)
Nice welding what make and model mig no you use.
EAP
#7 Posted : Sunday, 1 January 2006 8:04:17 PM(UTC)
What a great looking car. Well done on keeping it original. I can't believe they hacked off the guards to put flares on it. Motor looks very good as well, Regards Simon
#8 Posted : Sunday, 1 January 2006 10:57:18 PM(UTC)
Holy **** that engine looks sweet with the triples! wot else has you done to it, eg. head, compression, pistones and all that stuff.
well done man that looks sweet and it will haul ass
zac
Nothing beats cubic inches !!!
#9 Posted : Tuesday, 3 January 2006 10:47:18 PM(UTC)
yes it is a gtr
202 plus 40thou
steel crank
xu1 hinged sump
hi vol oil pump
7500 rpm balancer
gilmer pulleys
bl
#10 Posted : Wednesday, 4 January 2006 1:41:33 AM(UTC)
You've done an extremely good job on it! I just saw the photos for the first
time then - MARVELLOUS!
My motor didnt come up anywhere near as good as that did! You've gotta be proud
of that! Almost good enough to put on the mantle piece! WOW is al
#11 Posted : Wednesday, 4 January 2006 7:53:28 AM(UTC)
I agree with kieth and i cant wait to see the finished product
zac
#12 Posted : Thursday, 5 January 2006 11:17:40 PM(UTC)
my god - your dedication is nothing short of awe inspiring.
if that were me finding ou tthe chassis was bent, i would have parted the thing out.
good on ya for keeping at it - and the engine looks awesome.
what colour are you planning?
think m
#13 Posted : Thursday, 5 January 2006 11:32:22 PM(UTC)
gunmetal
#14 Posted : Friday, 6 January 2006 1:13:25 AM(UTC)
nice.
think more, post less.
CherryBomb Offline
#15 Posted : Thursday, 2 February 2006 10:30:41 PM(UTC)
CherryBomb
Geez-zuz, That is one sick looking six!
And the Body Work is second to none!
Are you planning to 'Show' the car much once compleated?
Man, That is nice!
Never stop being inspired,
#16 Posted : Thursday, 9 February 2006 7:19:28 AM(UTC)
thanks for the comments as for showing i dont think so it will probably end up sitting in the garage with my other car r8 clubsport (3 1/2 years old and done 11000 klms ) have all good intentions of driving them but time will probably kill that as we ve j
CherryBomb Offline
#17 Posted : Friday, 10 February 2006 4:42:47 AM(UTC)
CherryBomb
Either way mate the experience would be all that more sweeter on that Odd occasion that the little beast was to see day light. :)
Dan
#18 Posted : Tuesday, 14 February 2006 6:49:06 AM(UTC)
man you have to make time for something like that!
by the way you have done a great job>
let us no when shes all finished and post up a couple of photos
zac
#19 Posted : Thursday, 4 May 2006 12:56:47 AM(UTC)
nice mate
#20 Posted : Friday, 12 May 2006 5:37:58 AM(UTC)
Great job,The torrie will live again!Beautiful job on engine,Looks very very nice.
Guest (18)
This page was generated in 0.154 seconds.
