#1 Posted : Tuesday, 6 October 2009 4:02:36 AM(UTC)
are salibury centres all the same?
for example would a centre out of a HZ fit a HG?
#2 Posted : Tuesday, 6 October 2009 4:05:29 AM(UTC)
Was thanked: 616 time(s) in 583 post(s)
No. HK-HG are Chev 10 bolt. HQ-WB V8, VB-VK 308, A9X and VB rally car are all Aussie 10-bolt. Very different. There are also 4 x centres for Aussie 10-bolt:
2.6/2.78:1 open;
2.6/2.78:1 LSD;
3.08 - 4.44:1 open;
3.08 - 4.44:1 LSD.
#3 Posted : Tuesday, 6 October 2009 4:20:31 AM(UTC)
thanks mate
i have a 3.08 centre for sale, it is out of a HZ diff (V8) and i got a email from a guy asking if it would fit his HG, and i wasnt sure so id thought id better ask
another question, is there a easy way to tell if its lsd or open when its out of the car?
#4 Posted : Tuesday, 6 October 2009 4:37:48 AM(UTC)
You get someone to hold the axle flange on one side & then try & rotate the flange on the other side.
If it rotates easily, its an open centre. If it doesnt rotate, its an LSD. If it rotates but its a bit tight, then its a stuffed LSD (quite common).
Dr Terry.
Michael_4 Offline
#5 Posted : Tuesday, 6 October 2009 5:27:37 AM(UTC)
Michael_4
Just a quick question
I jacked up my left rear on my HQ last night to spin the wheel to check if the bearing is noisy with the tyre on and it only turned a little them jammed does this mean its LSD...???
#6 Posted : Tuesday, 6 October 2009 7:20:03 AM(UTC)
Make sure that the transmission is in neutral, otherwise the tailshaft is locked & you wont be able to turn the left-hand wheel very far at all.
Dr Terry.
Michael_4 Offline
#7 Posted : Tuesday, 6 October 2009 11:00:11 PM(UTC)
Michael_4
rrrrrrrrrrrr yes thanks for that Dr Terry. Will try again.
