steveR Offline
#1 Posted : Wednesday, 7 October 2009 4:56:01 AM(UTC)
steveR
hey there guys, i have a hj 308 with a rochester 4b, yella terra roller rockers, and i think a mild cam i wouldnt mind a bit more power, any ideas?
#2 Posted : Wednesday, 7 October 2009 5:02:30 AM(UTC)
Was thanked: 616 time(s) in 583 post(s)
If the engine is due for a rebuild stroke it to 3.48". Cheapest and easiest power/torque increase per unit.
If the engine is OK:
New cam and lifters degreed in properly;
Adjustable timing chain set;
Extractors and decent exhaust;
HEI dizzy;
Rebuilt Rochester.
Change to 3.55 diff gears to give it more go if its only used around town.
#3 Posted : Wednesday, 7 October 2009 6:14:28 AM(UTC)
Auto or Manual?.big difference.
Jim in adelaide
#4 Posted : Wednesday, 7 October 2009 6:30:32 AM(UTC)
cheapest power upgrade (if you havent already) is to upgrade your spark, first and easiest thing to do is to put in a HEI dizzy, then maybe something like a msd ignition, and some brisk plugs, thats exactly what i did chacing some quick and easy power, the differance was huge in all areas, cold starts expecally better
really depends on your budget and thirst for more power
steveR Offline
#5 Posted : Thursday, 8 October 2009 2:01:27 AM(UTC)
steveR
the ute in auto...
have done the exhaust 3inch and extractors..will look into the diff.
cheers guys
#6 Posted : Thursday, 8 October 2009 3:13:04 AM(UTC)
what about your ignition steve? points or HEI?
greenhj Offline
#7 Posted : Thursday, 8 October 2009 5:00:24 AM(UTC)
greenhj
Was thanked: 15 time(s) in 13 post(s)
cant see any advantage to an MSD over a properly rebuilt and curved standard HEI.
For 90% of road going vehicles NOT running 9s, your money will be better spent elsewhere.
11.38@117
#8 Posted : Thursday, 8 October 2009 5:55:14 PM(UTC)
dont waste your time or money with a stroked/beefed up plastic, just put a big block in it and you will have tonnes of torque and power, and if its late model Gen 5 or 6, its easy, cheap, reliable and awesome
"We wreck = KNOWLEDGE" lolololol
#9 Posted : Thursday, 8 October 2009 6:29:53 PM(UTC)
If its a TH400 (which it should be for a 308 auto HJ), then Frank isnt all that far off the mark, but a BBC might be a bit much for you. Maybe a 350, stroked 350 or 400 might be something worth thinking about? I know it means new exhaust and radiator but you may need these for the 308 anyway? And if you were contemplating a rebuild with new inlet, dizzy, carb etc it might be worth thinking about.
Note also that a better torque converter for the TH400 is also worth consideration. A new dominator suited to your application isnt all that dear and will improve a TH400 out of sight. I bought a powertow Dominator converter built to suit a BBC for about $500.
