Jvanner Offline
#1 Posted : Thursday, 8 October 2009 11:29:40 PM(UTC)
Jvanner
my mate wrecked a VB Commodore. the block engine number is 308H. looking on Monaro parts it says HT-G block. but the casting date is L18. i thought it could be 1st Nov 68 casting. would this make it a HK block as i thought HK never had a Holden V8 fitted to them. so im confused. will someone help please.
74HJLS Offline
#2 Posted : Thursday, 8 October 2009 11:45:37 PM(UTC)
74HJLS
Could be a 78 block that has been re stamped?
Pete.
Pete.
#3 Posted : Friday, 9 October 2009 3:28:31 AM(UTC)
Was thanked: 616 time(s) in 583 post(s)
What is the engine number, ie how early is the number after 308H? Very first engine stamped in this series was 308H1001. L18 cannot be 1978, has to be 1/11/68. Maybe a 308 prototype. Unless its actually L189, L180 or L181
castellan Offline
#4 Posted : Saturday, 10 October 2009 4:12:56 AM(UTC)
castellan
Has it got HP on the block with a small S above the HP.
It maybe just the casting is shoddy. there are other ways to tell by looking at the cam Vally the old ones have a dip. or the length of the 4 head bolt casting in the valley. ect
Is it the original stamping number.
Jvanner Offline
#5 Posted : Saturday, 17 October 2009 6:51:40 AM(UTC)
Jvanner
more info.its L18 cast. the engine number is 308H2557 and where the 308 is usually on side of the block it has the letters HP.
#6 Posted : Saturday, 17 October 2009 8:31:39 PM(UTC)
Defintely early HT, almost certainly Brougham.
castellan Offline
#7 Posted : Saturday, 17 October 2009 11:53:02 PM(UTC)
castellan
It has to be E189 = 18/5/1969 for a 308H 2557 engine number.
I have come across a E199 = 19/5/1969 with 308H 2624.
I had a E189 but it had a QLD police number.
If you are pulling down the motor you should see a HP crank and conrods are forged differently to the other 308s. bigger forging along the rods shaft.
