Does anyone have any experience with the reproduction GTS steering wheels?
Not sure whether HG should be black plastic or the walnut?
Rares say the ebay ones are runnish and visa versa...
Also the repoduction boss etc.
Jeremy |
The G will roll again.... eventually |
HG and HT are the black ones, made in Australia by Bridgstone for GMH. The repros I remember seeing were no good. HK Walnut were made in the USA and the US made repros are excellent.
the rares repro HT & HG wheels are from the states made in taiwan and they are the wrong offset 2inch instead of 4. i bought one direct from the states(classic industries) they call them the comfort grip to suit chevelles and the like.also heard reports the the repro ones tended to bend easily.
Was the one you bought made by Grant??
They seem thicker than the GMH ones going by the photo...
Also, does it have the stainless steel bit around the outside of the rim?
Jeremy |
You are a member of these groups:: Registered
The HT HG wheels from the states are not the wrong offset they are repos to suite corvette and other GM cars of that era..
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
they look like our ones with the ring on the outside, and they are the wrong offset for our cars or should i say two inches closer than our ones are !
The Repro wheels are the wrong offset , as they were made to suit cars with Tele/Tilt Steering colums in America . At this point no one makes a correct Repro HT HG LC Black wheel that i am aware of . www.monaromuscleparts.com
Theres one advertised on Ebay that says it has the correct 4 inch offset and 15 inch diameter, but its clearly too thick and does not have the stainless around the rim.  Its obviously not a reproduction, but seems to be reasonably good value for a good aftermarket wheel - got to be better than the thin Premier tiller :) Has anyone bought one? Edited by user Wednesday, 14 October 2009 7:21:56 AM(UTC)
| Reason: Not specified |
Just buy a HK replica from the US. Right size, offset and spokes and fits the centre. Just isnt black with the ring.
Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Is their anyone that retro fits the s/s ring to these wheels
So what is the correct offset and size??
Is it 4 and 15inches?? |
i found out the hard way today ,the ring on the outside does not appear to be stainless steel but more of a mild steel/alloy as we cut it and tryed to make it slightly smaller with a TIG welder turned down to 3-4amps to make it fit tighter.but it all turned to s#*t. the ring material was softer than the mild steel filler wire.any ideas on what it made of ?
Jeremy, the "thin" Premier wheel is similiar in thickness to the GTS wheel, that was the fashion in those days. I got mine done in 2 pack to match the rest of the dash, mind you I did scour the earth to find a good steering wheel and because my HK is an early one the steering wheel had to be round not ovoid.
Many years ago I was given a LC GTR wheel with boss but without horn cap & cap base & missing stainless ring around the outside,I re-discovered It in a box of dirty old car bits,It took me ages but eventually I got cap & base & repainted them cost me about $220 I discovered a seller called "The Rimshot buddy" in the states & he sold mylar tape the correct size to fit in the space of S/Steel ring,It looks pretty good,But I doubt it would satisfy hard-core purists.On the GMH Torana website I read in a forum there that there was a bloke who said he coud replace the missing stainless ring with an aluminium one the same dimensions etc. for aboutt $230. SL loon
Hi all ,first time on here To fit(repro GTS steer wheel)2 problems i found were blinker cancelling pins poor fit in boss ,use some loctite. Horn button really loose fit to backing plate ,drill n tap 3 small holes in cap edge where the divits are m2 thread worked and use screws to hold cap on . ebay item , not real happy with it .modified it to make it work .
Hi, exact reproductions of the hk monaro steering wheel & the ht hg monaro steering wheel, with the correct pitch,outer steel band & boss kit,are being made now.These will be available through - HARRISONS EARLY HOLDEN & FORD SPARES UNIT 1- 46 BLANCK ST., ORMEAU 4208. (07)55490351. Many more parts are being made for this model & other models of Holdens,Fords. Ive just updated my new products list last night. Email me for a list - [email protected]ps. I need help with new genuine body rubbers for Holdens & Fords to copy.They will be made out of epdm rubber that will be better than factory. Without your help with samples this just wont happen. If you want better rubbers than factory,let me know what samples you can help me with samples supplied will be returned as supplied & free items given. MERRYCHRISTMAS & A SAFE & HAPPY NEW YEAR TO ALL, PAUL HARRISON.
PAUL HARRISON |
PAUL HARRISON |
Thanks Paul
When and how much?
The G will roll again.... |
I too am looking forward with great interest about when and how much.If its priced right,i will take one.
Hi Jeremy, correct copies of these with the right pitch are being made now for the hk & ht hg gts & will be available through - HARRISONS EARLY HOLDEN & FORD SPARES sometime in the early new year.No pricing yet,it will all depend on how many i order in the first lot.The more orders i have,the cheaper theyll be for everyone.If your interested in these,put your name on our list & ill let you know when the samples are approved & pricing.To do this or to be sent a list of all the new parts made or being made, email [email protected] or ph.(07)55490351. cheers Paul Harrison.
PAUL HARRISON |
PAUL HARRISON |
