#1 Posted : Saturday, 24 September 2005 3:10:04 AM(UTC)
Hi all, my WB seems to need extra plugs that the HX instuments dont have ? Is there a way around it ? I was thinking of swapping it for a yellow needle one. Are the HZ ones the same as WB or are they different too ?
Also does the WB GTS style fuel guage match with the older sender, the WB book says 283 - 40 ohms but I think thats Statesman...doesnt mention the GTS style dash which a lot of WB`s had fitted.
#2 Posted : Saturday, 24 September 2005 4:11:15 AM(UTC)
Hi Trav.
All the senders are the same from HJ to WB (except WB Statesman).
The HZ/WB yellow needle GTS type dash will work OK with HJ/HX senders.
Dr Terry.
classic oz wreck Offline
#3 Posted : Saturday, 24 September 2005 6:57:11 AM(UTC)
classic oz wreck
yellow needle and white needle gts dashes have different wiring harnesses which will plug into the main harness from hj to wb...have you got the correct harness for the dash?
www.classicozwreck.com.au
#4 Posted : Saturday, 24 September 2005 8:25:38 AM(UTC)
yeah the dash has the correct harness for an HX, but I am trying to put it into a WB panno. So if I find a HZ (yellow needle) dash harness it sould be all good ?? Might be able to do some mods to the HX one ?? The WB has an extra 3 pin plug that goes to
