Hi all, my WB seems to need extra plugs that the HX instuments dont have ? Is there a way around it ? I was thinking of swapping it for a yellow needle one. Are the HZ ones the same as WB or are they different too ?
Also does the WB GTS style fuel guage match with the older sender, the WB book says 283 - 40 ohms but I think thats Statesman...doesnt mention the GTS style dash which a lot of WB`s had fitted.
Hi Trav.
All the senders are the same from HJ to WB (except WB Statesman).
The HZ/WB yellow needle GTS type dash will work OK with HJ/HX senders.
Dr Terry. |
yellow needle and white needle gts dashes have different wiring harnesses which will plug into the main harness from hj to wb...have you got the correct harness for the dash? |
yeah the dash has the correct harness for an HX, but I am trying to put it into a WB panno. So if I find a HZ (yellow needle) dash harness it sould be all good ?? Might be able to do some mods to the HX one ?? The WB has an extra 3 pin plug that goes to
