RussVRute Offline
#1 Posted : Sunday, 25 September 2005 6:05:52 AM(UTC)
RussVRute
G'day All,
I am asking this for a mate who doesnt have a computer, he wants to put a VH Commodore Standard 2 barrel carby off a 202 blue motor, on his 202 red motor, and wants to know if it is an easy conversion, and if it will affect power and fuel economy to any marked degree? He said he saw a blue motor manifold and it has the throttle assembly bolted to the manifold, but a 2 barrel red motor conversion manifold which he has got has nowhere to bolt the throttle mechanism to,is this an easy problem for him to get around? any advice I can pass on will be greatly appreciated.Thanks. Russ.
P.S. for the benefit of my curiosity also what is the difference between a single barrel and a 2 barrel as far as performance etc, is concerned?
#2 Posted : Sunday, 25 September 2005 6:33:58 AM(UTC)
He is heaps better off fitting an S (2600S, 2850S or 186S) manifold and WW Stromberg carby. Greg at Classic Oz Wreck (watch ads above) should be able to help him out with bits.
#3 Posted : Sunday, 25 September 2005 7:17:12 PM(UTC)
i just had a WW2 + manifold (both on ebay-$100) recoed by http://www.xtremefuelsystems.com.au/ (around $220 inc. post) also bought a set of x2 exh. manifolds off ebay for $80, combined with an elec. dizzy/coil for $50 i'm (hopefully ) set...
[IMG]http:
Edited by user Sunday, 25 September 2005 7:19:45 PM(UTC)  | Reason: Not specified
RussVRute Offline
#4 Posted : Sunday, 25 September 2005 11:21:44 PM(UTC)
RussVRute
G'day All,
Thanks for the replies, but he already has the carby and manifold and doesnt want to buy another one, as he is not excactly a millionaire! he just wants to know if it can be fitted easily or not, and how to get around the throttle mounting bei
Edited by user Sunday, 25 September 2005 11:24:29 PM(UTC)  | Reason: Not specified
#5 Posted : Monday, 26 September 2005 10:59:01 PM(UTC)
Hi Russ,
The WW is the model of the 2 barrel Stromberg carby that Holden used on the red 6's and the 253's.
The varijet are not known for their economy or power :-( Additionally, the blue manifold won't fit the red head...
Cheers...Dave
#6 Posted : Thursday, 6 October 2005 9:56:49 AM(UTC)
Arent the mounting studs different between red and blue motors? I think the ports are all different too so the flow going into the head might be freaked out a bit. Just a sugestion, Im not 100% on that. Definately check that the ports are all the same siz
