satanic customs Offline
#1 Posted : Tuesday, 20 October 2009 8:03:19 AM(UTC)
satanic customs
as above, bought a 94 exec at auction, price was right, but no key!
how do you start it? new key? new barrel and key? i want to wreck anyway, would rather not spend money on it if i dont need to... how do thieves hot wire them? would a new second hand column do the trick and if i go that way will the key need to be reprogrammed? cheers
#2 Posted : Tuesday, 20 October 2009 8:57:51 AM(UTC)
Youll need a keyhead to match the BCM to disable the security system.
Best off not bothering if its only to wreck out. Tilt-tray will be quite a bit cheaper.
However, if you find someone wrecking the same year model, and same trim level VR (luxury ones had a different to the base models, and early/late differ too) then you could get the barrel, key & keyhead off them.
If you dont need to steer it, you can pull the back off the ignition switch & turn it, but without a valid keyhead in it, the BCM wont disable the security.
bundybluedog Offline
#3 Posted : Tuesday, 20 October 2009 7:26:12 PM(UTC)
bundybluedog
if you live north side of brisbane i have a locksmith who does cash jobs. he has the computer to make the key. it not to cheap though would cost over 100 even as a cash job. holden charge $220
Anyone on here that needs locks done for the old cars and lives nothside pop me an email my mate can help you out.
adam PERTH Offline
#4 Posted : Tuesday, 20 October 2009 10:16:25 PM(UTC)
adam PERTH
hard to wreck driveline without "hear running" or guarantee.
spend the $100
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
#5 Posted : Wednesday, 21 October 2009 6:03:20 AM(UTC)
buy a cheap manifold an carby ,fire it up n sell it with the injectors then sell off the carby etc...would that work?(i dont know much about these)
Jim in Adelaide
gts308 Offline
#6 Posted : Wednesday, 21 October 2009 8:19:15 AM(UTC)
gts308
If your in Sydney just ask any resident of Redfern how to start it without a key...Ha Ha!
"We are but a grain of sand on the beach of life"
petaus Offline
#7 Posted : Wednesday, 21 October 2009 4:24:32 PM(UTC)
petaus
if you can bust the barrell leave the ignigtion on i think for 30 or it might be 45 minutes and the alarm light will stop flashing then it will start, this is a over ride if a key pad stuffs up.
pete.
#8 Posted : Thursday, 22 October 2009 5:16:23 AM(UTC)
^^ That will work if it has the timed over-ride on the BCM.
Check the passenger door pillar, if it has a key lock in it (like VPs and quite a few VRs have), then the timed-override wont work, as it requires the key lock to be turned to disable the security.
Assuming you only want to start it, and not drive it, then using the over-ride method, you will only need to pull the black plastic bit off the bottom of the barrel (2 small screws) and turn the centre of it with a screwdriver.
Casper Offline
#9 Posted : Thursday, 22 October 2009 10:35:15 AM(UTC)
Casper
Drill out the 2 rivets and bridge the wires.
Its just a switch.
#10 Posted : Saturday, 24 October 2009 2:58:15 AM(UTC)
satanic customs
this is why i love this forum... people who are in the know go out of their way to assist those that arent... thank you all very much for the advice
horns up
#11 Posted : Sunday, 25 October 2009 5:48:08 AM(UTC)
ask the local louts they will start it for you lol
This page was generated in 0.136 seconds.
