#1 Posted : Wednesday, 28 October 2009 6:29:06 AM(UTC)
Hi all (hopefully Dr Terry an Byron aswell), factory torque converter stall speeds?Any-one know what they are as I heard they were as low as 1200 to 1400.Is this true?
Jim in Adelaide
peter_flane Offline
#2 Posted : Wednesday, 28 October 2009 7:25:53 AM(UTC)
peter_flane
Well lets say a HQ 6 cyl Trimatic for example?
#3 Posted : Wednesday, 28 October 2009 8:16:33 AM(UTC)
Sorry, I forgot 308 x turbo 400.thanxz Pete
Jim in Adelaide
Edited by user Wednesday, 28 October 2009 8:17:09 AM(UTC)  | Reason: Not specified
#4 Posted : Wednesday, 28 October 2009 9:01:17 AM(UTC)
Stall torque ratio of a HQ TH400 is 2.1:1 if that helps.
#5 Posted : Wednesday, 28 October 2009 9:04:41 AM(UTC)
Sorry Byron,you lost me (not that hard now a days)what stall would that work out to 2100?or 1100?
Jim in Adelaide
#6 Posted : Wednesday, 28 October 2009 9:59:41 AM(UTC)
think you will find the V8 was about 1200 to 1400 the 6 about 1900.
#7 Posted : Wednesday, 28 October 2009 3:49:04 PM(UTC)
Thanxz John and Byron.
Jim in Adelaide
#8 Posted : Wednesday, 28 October 2009 4:15:50 PM(UTC)
Jim, dunno. That came straight out of GM literature. This link tells you what STR is:
http://www.700r4l60e.com/torque_ratio.html
peter_flane Offline
#9 Posted : Thursday, 29 October 2009 4:29:34 AM(UTC)
peter_flane
So what was the stall of a HQ 6 cyl Trimatic. About 1900rpm?
#10 Posted : Thursday, 29 October 2009 5:01:41 AM(UTC)
From what I understand, stall is a function of the torque curve of the engine, so what the stall is would depend upon which HQ 6cyl the box was installed behind, ie 130, 173LC, 173HC, 202LC or 202HC.
peter_flane Offline
#11 Posted : Thursday, 29 October 2009 5:06:58 AM(UTC)
peter_flane
Lets say HQ 202 HC.
#12 Posted : Thursday, 29 October 2009 5:19:24 AM(UTC)
Thanxz John, Peter and Byron, Im sure this is a question that will help every one who wants to know.Byron ,I agree ,i think the converters are a standard fit,IE 6cyl all the same ,V8 all the same and the torque of the engine dictates its inherent stall levels. Ive got a 2200 stall for my mild 308 t400.I got it cheap from a trusted mate ($120)and I am wondering what difference it will make above the stall of a standard.He said it will liven it up a bit,Ive never ran a H/S before,any comments?...but Ive already got it and wont be changing to another stall as its a done deal. But any comments would be appreciated .Ps Im gonna run mainly gas if that makes any difference.
Jim in Adelaide
#13 Posted : Thursday, 29 October 2009 9:09:45 AM(UTC)
my 202 had a stall of about 1900, stock, when I converted to EFI it was definitely too low, take off at the lights was very slow, (although was at the normal previous take off) I would have been better off to fit a Gemini convertor which stalls around 2200-2400.
The problem is that the engine does not get to its best RPM torque at take off and so bogs down.
Guest (5)
