jayHK69 Offline
#1 Posted : Monday, 2 November 2009 7:37:34 PM(UTC)
jayHK69
Are the brakes on a HK-T-G 10 bolt the same as the brakes on a HQ 10 bolt ?
jayson
#2 Posted : Monday, 2 November 2009 8:05:37 PM(UTC)
Most of the parts are different. A lot of the smaller hardware is the same.
The wheel bearing on the HK/T/G is larger in outside diameter, therefore making the hole in the backing plate larger. The backing plate also has a bigger offset.
Drums are different in bolt pattern & offset.
Most HK/T/G with a 10-bolt would have had front disc brakes, meaning that the rear cylinders are smaller & the brake shoes are different in profile. HK/T/G with front drums will have the same rear shoes as all HQ-WB.
jayHK69 Offline
#3 Posted : Monday, 2 November 2009 9:45:16 PM(UTC)
jayHK69
thanks dr terry. just bought hk-t-g 10 bolt that needs brakes fitted was hoping to use the parts from a hq diff i have, but not so.
maybe a stupid question but are any hk-t-g banjo parts interchangeable with the 10 bolt, wheel cylinders (with disc front) brake adjusters etc ?
jayson
#4 Posted : Tuesday, 3 November 2009 2:52:37 AM(UTC)
To my knowledge all the rear brake stuff is interchangeable between Banjo & 10-bolt in HK/T/G, with the exception of the front drum & disc versions.
Dr Terry.
Keeo Offline
#5 Posted : Tuesday, 3 November 2009 5:33:39 AM(UTC)
Keeo
The 10 bolt i have has got a 3mm spacer on the outside of the drum .
What was this for ?Is it an original set up (factory).The diff is from a monaro hk and it had tramprods.
jayHK69 Offline
#6 Posted : Tuesday, 3 November 2009 5:33:36 PM(UTC)
jayHK69
thanks again dr terry
jayson
#7 Posted : Tuesday, 3 November 2009 5:57:45 PM(UTC)
The 3mm spacers were added to the rear of GTS327 & GTS350.
AFIAK it was for increased clearance between their wider D70H14 tyres & the tramp rods.
GTR XU1s also had these spacers.
Keeo Offline
#8 Posted : Wednesday, 4 November 2009 4:42:07 AM(UTC)
Keeo
Thanks for the reply doc. I shall put them on the shelf then.less weight= more freight.
jayHK69 Offline
#9 Posted : Wednesday, 4 November 2009 6:44:23 AM(UTC)
jayHK69
dr terry can i take the complete drum from the banjo & bolt it onto the 10 bolt ?
jayson
