#1 Posted : Friday, 30 September 2005 11:35:02 AM(UTC)
I got myself a VL SL, first car, and i wanted to know if theres anything i could do to improve it, so far got sound system, but i was thinking more about the engine, any suggestions and information would help
#2 Posted : Friday, 30 September 2005 10:27:22 PM(UTC)
If it's a V8 you can convert it to an EFI out of a VN, but I wouldn't do that as it would be cheaper to buy a VN. You could also convert it to a later V6, but again probably cheaper to buy a complete car and sell the VL. You are probably better off spendi
trubluhq Offline
#3 Posted : Saturday, 1 October 2005 3:55:30 AM(UTC)
trubluhq
VL Nissan donk....a very good engine. Pity about the electical system beneath it.
Also if you are not mechanically minded and DO NOT have a swag of tools, get the timing belt replaced. Now ! With tools its easy, without tools, its a pain !
#4 Posted : Monday, 3 October 2005 8:41:59 PM(UTC)
and keep an eye on the temp gauge.
alloy heads on the VL's seem to like to warp if not looked after.
just an exhaust, filter, diff ratio change will make a noticable difference.
VN Calais, V8 Auto, Blown etc etc.
Air con, Electrical, Car audio Mas
#5 Posted : Tuesday, 4 October 2005 6:34:06 AM(UTC)
ok and a diff ratio is what? also my petrol gauge seems to have stopped working, is it the sender or something, or could it be electrical, and should i try fix it myself or is it a job for a mechanic?
#6 Posted : Tuesday, 4 October 2005 6:43:57 AM(UTC)
also, a few of my friends, who have no knowledge what so ever about cars but then again neither do i, talk about a sports clutch should i get one of those?
#7 Posted : Tuesday, 4 October 2005 6:51:34 AM(UTC)
you can get the gears in your diff changed so that the ratio is different.
it can increase acceleration, but lowers top speed.
if you only change it a little bit, you wont really notice the top end speed change.
a "sports clutch" is just a heavy duty o
#8 Posted : Tuesday, 4 October 2005 7:26:16 AM(UTC)
OK, it sounds like you are a true novice. If I were you I would follow all of the advice above, especially getting the cooling system checked and cleaned. This is important in a VL. My second choice would be the timing belt also as suggested above. By the
#9 Posted : Tuesday, 4 October 2005 7:42:21 AM(UTC)
thanks for the help, and yes it is a manual, i prefer them cos they r easier to stop but are they really better than autos? also the filter can u explain a bit more about it and the heavy duty clutch will this make my gear changes more smooth? and i will
jabba Offline
#10 Posted : Tuesday, 4 October 2005 3:57:17 PM(UTC)
jabba
A heavy duty clutch will not make gear changes smoother. It may have the opposite effect in that they can be a bit "grabbier" and will be a lot more sensitive to pedal position. What they will handle is being dumped on alot better (boy racer take-offs).
#11 Posted : Tuesday, 4 October 2005 6:14:49 PM(UTC)
He means a higher flowing air filter I think. The EFI electrics on a VL are inferior to later stuff. It's one of the prices to pay for having a car with older technology. Don't sweat, they can be troubleshooted readily and there are heaps of VL's left to
#12 Posted : Thursday, 6 October 2005 6:26:04 AM(UTC)
yep there are alot, and what your saying is its not the clutch thats the problem, it my sucky gear changing. and why did they put such a confusing computer in it, it really is wierd, u have to sit there counting flashes
Edited by user Thursday, 6 October 2005 6:28:43 AM(UTC)  | Reason: Not specified
#13 Posted : Thursday, 6 October 2005 10:39:49 AM(UTC)
Tilly I am not knocking you but you really picked the wrong car if you are inexperienced enough not to know about diff ratios etc. If you want to learn about cars you would have been far better off to pick an earlier model, even a VH or carby vK. They ar
#14 Posted : Thursday, 6 October 2005 11:03:29 PM(UTC)
yeah maybe your right, i gotta get some mags, and since you all have such good knowledge of mechanics maybe you could tell me what, if anything, is wrong with my second gear it chugs along and when i accelerate its simuilar to bunny hopping, except not as
Edited by user Thursday, 6 October 2005 11:09:10 PM(UTC)  | Reason: Not specified
This page was generated in 0.088 seconds.
