#1 Posted : Saturday, 1 October 2005 2:30:42 AM(UTC)
DO YOU NEED A DEMISTER WORKING FOR REGO ?
BARGAIN BRAND NEW UNDER DASH HEATER AND AIR CONDITIONING
WITH DEMISTER DUCTS AND EYEBALL DUCTS
TO SUIT HOT ROD, 4WD OR OTHER AUTOMOTIVE application
THE UNIT IS NEW ,THE CASING IS PLASTIC AND HAS BOTH HEATER EVAPORATOR CORES INSIDE UNIT
HEATER CORE IS ALUMINUM WITH 16 MM OUTLETS
OVERALL dimension are as below
HEATER AIR CONDITION Specs
CUBIC FEET METRE 359
Dimensions 400 MM X 325 MM X 125MM
COOL K/CAL 2650
HEAT K/CAL 4800
Volts 12
2242EV
The unit has a twin blower wheels with a three speed 12v motor
THIS UNIT IS COMPLETE WITH 2X DEMISTER DUCTS , 2X EYEBALL AND ONE UNDER DASH HEAT/COOL EVAPORATOR
$350.00 INC GST
NOTICE: TRADE & WHOLESALER WELCOME Email for price
www.geocities.com/radiatorexpert/ OR EMAIL [email protected]
PLEASE NOTE : YOU WILL NEED A/C COMPRESSOR , CONDENSER ,R/DRIER AND A/C HOSES
trubluhq Offline
#2 Posted : Saturday, 1 October 2005 3:51:58 AM(UTC)
trubluhq
Unlike modern cars with NO flow thru ventilation eg VR-VX commodes, the old HQ can get by without even a fan ! That's why modern cars need aircon.
John
#3 Posted : Saturday, 1 October 2005 4:02:22 AM(UTC)
Hi trubluhq.
The HQ holden was the 1st Holden WITH flow-thru ventilation. It had face-level dash vents & outlet vents in the rear door openings. They also had no glass quarter vents on the front doors.
Dr Terry.
Munromad2004 Offline
#4 Posted : Saturday, 1 October 2005 5:20:34 AM(UTC)
Munromad2004
The factory manuals for the HQ have very detailed drawings of the direction of airflow throughout the cabin and boot area.
I never knew how much thought and planning actually went in to designing the air circulation system on a car. Quite an eye opene
#5 Posted : Saturday, 1 October 2005 8:30:57 AM(UTC)
I had visions of modifying mine to fit HG or something quarterwindows. Flow through just does not work properly in the heat of australia.
Mr Void Offline
#6 Posted : Saturday, 1 October 2005 7:03:47 PM(UTC)
Mr Void
Ummm, how would a mechanic test the demister to see if it was working anyway?
I am doubting they are going to stick a voltmeter across it....
___________________
Why are you reading this, you should be looking up there^^
___________________
#7 Posted : Saturday, 1 October 2005 7:27:03 PM(UTC)
They just see if its blowing hot air onto the windscreen, in the mini's with out heaters they just used a 12 volt hairdryer up under the dash:) These units are cheaper than the vintage air units, guess see if blokes run them and if they cool a large 4 doo
#8 Posted : Sunday, 2 October 2005 2:57:14 AM(UTC)
my hk kingswood has no fan whatsoever...no radio either :| has disc brakes though
in reply to the original post, only if your car had it in the first place ;)
i think i'll have another look at that website though, i still want a heater!
[IMG]http
