Fastlane
Holden Forums
Holden General Discussion
are power steering pumps different? 6cyl vs V8
Hi all,are power steering pumps different? 6cyl vs V8.Aside of the mounting positions/angles,as Ive got a 6cyl one but need a v8 one,but might just make up a mounting plate ,,any help please.P.S IF ANYONE WANTS TO SWAP OR CAN HELP.I've got the pump and bracket/plate (6 cyl) Jim in Adelaide Edited by user Sunday, 8 November 2009 3:59:11 AM(UTC)
| Reason: Not specified |
Jim in Adelaide.. |
hi jim, the pumps are the same, its the brackets that are different, i have a V8 bracket and spacers here, if you cant find anyone local to swap, then ill swap you, well just have to post them thats all
Hi ,Dave I have bolts and spacers etc ,so I just need the bracket is that right?I would be willing to post brackets "to and fro" not a problem,let me know,as Im ready to bolt it on(temporarily fitment). Ps (From the other thread) how much for a swap on the chromey?.....mob ph# 0401 975 612 Jim in Adelaide Edited by user Sunday, 8 November 2009 7:09:51 AM(UTC)
Jim in Adelaide.. |
Jim, Rare Spares sell the spacers if you need them. Also VN rear seat belt spacers are just about spot on too. Try a few and get the ones without the step in the end.
Thanxz Byron ,I was in a panic ,a mate sold me the power steering complete but it doesnt fit because of the bracket,Ive bought bolts and spacers off eBay, so once i get a bracket it should be a go!
Jim in Adelaide |
Jim in Adelaide.. |
V8 bracket is easy to find, 6cyl is harder. Just be careful of which crankshaft pulley you use. With standard alternator bracket HQ-WB uses a 2 or 3 row pulley that has the innermost pulley hard up against the balancer. Commodore have a gap to the first pulley, although I have seen cast iron 3 row pulleys that are the same config as HQ-WB on EFI engines. From memory HQ-WB has the power steering on the innermost pulley and alternator on the second row with A/C on the outside.
Byron ,you are dead right again ,thats the set up I got , I got a 308 (mild)from a statesman and it has the triple pulley on it as you described and 1..is pwr st ...2 is alt....3 is air(which ILL never use too expensive to hook up and I know nothing about them_).Your answer will help heaps of people IF they can be bothered to read ,that is the beauty of these forums ,I have never built a Holden before (just American cars and a few fords,chargers etc.long time ago!!)and ,I just surf here looking for the answers and usually find them.Thanxz for all the help so far(there will be more needed) as Im thing about HEI Ignition but dont know how to do it.
Jim in Adelaide |
Jim in Adelaide.. |
jim, go the HEI, you wont regret it, even go the brisk plugs, it WILL make a huge difference, work guide to installing a HEI here http://gallery.oldholden...lue_Electronic_Ignition/
Hi ,im a bit confused ive got that ignition already on the engine wb stato i think,i was after the one like on the American cars with no coil,or maybe i dont need to?
Jim in Adelaide |
Jim in Adelaide.. |
more HEI info here, just make sure if you do it, to get a bosch dizzy, they are found on commodores and WBs http://holdenpaedia.oldholden.com/Bosch_HEI
in the picture with the 4 types,ive got the 3rd one from the left with the proper coil ,but was after the 2nd one from the left as it runs an internal coil,is it worth it? they run good on american cars and it will clean up the engine bay a bit as im after a really simple engine bay look.but it is just a streeter and i maybe overdoing it .? Jim in Adelaide Edited by user Sunday, 8 November 2009 7:54:56 PM(UTC)
Jim in Adelaide.. |
 the third from the left is the 1 ive got too, ive been told there the best, sorry i dont know much about them, someone else will have to explain it ive got a MSD 6A comected to mine and it works great just stay clear of the procomp ones, there rubbish Edited by user Sunday, 8 November 2009 8:29:06 PM(UTC)
I Have never bought anything from companys that can sell things cheap,it is never good news with parts like that,if you cant buy good stuff new you are better off at the wreckers to be honest.I will leave it for the initial fire up because it all works fine,but later I might change over. Jim in Adelaide Edited by user Sunday, 8 November 2009 8:40:51 PM(UTC)
Jim in Adelaide.. |
3rd from the left is the factory holden bosch unit...stick with that... going to church makes you no more a christian than standing in a garage makes you a car... www.classicozwreck.com.au |
OK ,thanxz all, that was easy, Im all done!
Jim in Adelaide |
Jim in Adelaide.. |
Dave ,package on its way(complete) @ 3;00pm today
Jim in Adelaide |
Jim in Adelaide.. |
exellent, i sent yours at 5:00pm so we should recive them at the same time :-)
kool ,thanxz for that.
Jim in Adelaide |
Jim in Adelaide.. |
if you are after authentic look, then yes the 6 cyl pump is different to the V8, the 6 unit has a special double ended mounting bolt at the back, the V8 units just have a standard plug/bolt. easy enough to change over B4 you fill with fluid. also about the HX the bolts changed to metric, so make sure you have the correct bolts or you will strip the threds.
HOLDEN The Great Way to Move |
Monaro202...thanks for that info,yep got the right bolts(thankfully!).cheers
Jim in Adelaide |
Jim in Adelaide.. |
Fastlane
Holden Forums
