2 Pages<12
#21 Posted : Wednesday, 11 November 2009 6:05:14 AM(UTC)
monaro202, are the chev pumps the same? ive got 1 here and other then the pulley and the brackets they look the same
#22 Posted : Thursday, 12 November 2009 12:28:30 AM(UTC)
not sure on that one, only ever fitted a Holden V8 system to my L6 Kingswood. just had a squiz at the parts manual, the 350 pump has different mountings in the face of the pump & a seperate part No, so I would say they are different to L6/253/308...
#23 Posted : Thursday, 12 November 2009 3:02:47 AM(UTC)
Hi Guys.
I was going to post earlier on this topic but time ran out. As most of you guys probably know, Ive been repairing power steer units now for well over 30 years, so I can give a quick summary of the different types of pumps on Holdens.
If we restrict our discussion to the pumps which have the metal reservoir attached (HQ-WB etc.) it will keep it simple.
The pumps you are talking about were made by the Saginaw Division of GM & have been around since the 1950s. With Holden pumps there were 3 basic types of this style.
1. Narrow neck filler & imperial threads (bolt-on pulley)
2. Narrow neck filler & imperial threads (pressed-on pulley)
3. Ham-can style reservoir & metric mounting threads
The 1 to 2 changeover was late HQ
The 2 to 3 changeover was 1980/81 (early-WB & mid-VC).
Apart for the pulley attachment, types 1 & 2 are interchangeable.
Apart from the mount bolts, types 2 & 3 are interchangeable.
The earliest ones were fitted to the EJ series but they werent really commonplace until HK, where they were standard on Broughams. The 6-cyl types were different for each model. they even had a slight change for the X2 engines. 253 & 308 in HT/G were different again & had a remote reservoir if the car also had a/cond. The 307 & 350 style were Chev types & were slightly different (again) in the reservoir. The differences were in pulley offset & diameter, return spout shape & canister position (rotationally).
All the pumps HJ to early WB are basically the same with the exception of the extra mount stud at the lower rear of the 6-cyl pumps (as Monaro202 has rightly pointed out). Early Commodores complicated this somewhat because they also use the same pump, but they also had an extra stud in the upper rear for V8. When I say same pump, apart from the extra stud, everything (housing, reservoir & pulley) is the same back to HJ.
When the new shape (ham cam) reservoir came out in VC/WB (then VH/VK/VL) they were made interchangeable except for their metric mount bolts. Bolt hole position, body casting & pulley remained unchanged.
VK 6-cyl (& some VC/VH) used a smaller looking pump with a remote reservoir but the internals remained the same. VN to VT V8 used a similar pump to VC to VL V8 but the pulley & reservoir were altered.
#24 Posted : Thursday, 12 November 2009 3:32:22 AM(UTC)
top info doc, good to remember for futre refrance
jim, i got the bracket you sent me, and its a V8 one?
#25 Posted : Thursday, 12 November 2009 5:15:39 AM(UTC)
It wouldnt bolt to my 308,it would leave the reservoir at a 45deg angle(practically emptying itself)..?what holes do you use, i tried to use the top two and bottom left looking straight at the head from the front of the car.PS Ill call you when i get a minute OK?
Jim in Adelaide
Edited by user Thursday, 12 November 2009 5:18:52 AM(UTC)  | Reason: Not specified
#26 Posted : Thursday, 12 November 2009 6:20:55 AM(UTC)
this is a 6 cyl bracket
another 6 cyl bracket
v8 pump
#27 Posted : Thursday, 12 November 2009 6:32:18 AM(UTC)
DAVE COMPARE THE ONE I SENT TO THE ONE IN THE BOTTOM PHOTO FOR ANGLES?PS sorry about caps,,,doh
Jim in Adelaide
#28 Posted : Thursday, 12 November 2009 7:41:54 AM(UTC)
looks the same to me
#29 Posted : Thursday, 12 November 2009 6:07:41 PM(UTC)
Hi Guys.
A few more comments.
You often hear the term 6-cyl bracket or V8 bracket. In the case of the Holden 6-cyl (as seen in the above pics) it is not a bracket it is 2 brackets. The often missing rear support, which mounts the rear of the pump down to the RH engine mount always seems to get lost or forgotten. Most 6-cyl power steering conversions that I have had to fix are always missing the 2nd bracket. Many seem to think it doesnt matter, but if its not there it causes 2 problems. Firstly the pump will vibrate badly at certain RPM & the breather in the cap will just spew out fluid. It doesnt what you do it wont stop leaking until the rear bracket is fitted. Secondly, as a result of all this vibration, eventually the main (front) bracket will break. Not a good look.
Its the same with the various Chev pump mounts. Its not just one bracket, it is several brackets.
The comment above relating to the pump not sitting at the correct angle is what I was referring to by the reservoir rotation. Several years ago many cheap brand new pumps appeared at swap meets. These pumps were genuine Saginaw pumps, but they were Ford 6-cyl style. They were the same pump as the VC/WB metric Holden type except for the canister which was around 45 degrees different & may be the problem above.
#30 Posted : Friday, 13 November 2009 2:16:29 AM(UTC)
Hi Dr Terry and all , I think you are right as Dave and I discussed on the phone it may be a Chev pump or the ones youve just mentioned,DAMN.HOW TO FIX?
Jim in Adelaide
classic oz wreck Offline
#31 Posted : Friday, 13 November 2009 2:46:47 AM(UTC)
classic oz wreck
Originally posted by jim
DAMN.HOW TO FIX?
Jim in Adelaide
pretty simple fix really...buy the right pump from someone that knows what they are selling...
www.classicozwreck.com.au
#32 Posted : Friday, 13 November 2009 3:03:06 AM(UTC)
Yep it Was fitted to a wb statesman but the engine was removed already..what are the odds
of that?Anyway hes called me up and reckons hes found another pump,I bet you any money I know
what they look like NOW.....SORRY ABOUT THIS DAVE.
I should have known myself,but pulling it out of the car I didnt pick it
up and as weve discussed the bracket looked right(cause it was)
Jim in Adelaide
Edited by user Friday, 13 November 2009 3:06:04 AM(UTC)  | Reason: Not specified
#33 Posted : Friday, 13 November 2009 3:31:06 AM(UTC)
jim, i belive the mystery is solved, Dr Terry is correct, i recon you have a fraud pump
i have a pump in my shed off a EB falcon, so i got it out and it bolts up to the holden bracket just fine!!!
i then put it against the pump in my car and with the brackets lined up square against mine the pump lays over 45deg away from the engine!!
the ford pump is also the same shape as yours, (tear drop shape)
so i recon the doc is 100% right you have a fraud pump
#34 Posted : Friday, 13 November 2009 4:29:22 AM(UTC)
DAMN DAVE!...I hate it when that happens,a "FRAUD PUMP" Hey.let this be A LESSON TO YOU ALL! just because 1. a mate sells you it 2.and tells you its a holden 3.you pull it out the car yourself.4.it comes out of a holden.5 it is complete with steering box/bracket/hoses all fitted to it.6.the cars a wb statesman that was fitted with a v8(as most are)7.it looks familiar!.........be careful,it could be the dreaded "FRAUD PUMP"...LOL thanxz for all your help everyone.
Jim in Adelaide
#35 Posted : Friday, 13 November 2009 5:17:58 AM(UTC)
hahaha, very true, keep the pump for a spare, other than the outside casing, the pulley and the threads being metric the rest is the same
#36 Posted : Friday, 13 November 2009 8:54:55 AM(UTC)
Ive never built a holden before,always other cars,thats why I didnt know but I,ve learned alot in a year and a bit.
Jim in Adelaide
#37 Posted : Friday, 13 November 2009 8:47:02 PM(UTC)
this may help out, or just keep for reference. this is from the HQ Parts cat, it has the actual sizes in imperial for the spaces...
#38 Posted : Saturday, 14 November 2009 1:31:16 AM(UTC)
Good stuff Kevin,the canister holes are different than the one I got which I never
picked up on and it was a V8 setup I was after.He says hes got one,so Ill see.cheers
Jim in Adelaide
Guest (10)
2 Pages<12
