#1 Posted : Wednesday, 5 October 2005 11:52:06 AM(UTC)
Does anyone know somewhere online that I can buy an electronic ignition setup to replace the points in my 308.
Snoz
#2 Posted : Wednesday, 5 October 2005 4:40:15 PM(UTC)
In the FS section on here I have a HEI setup from a blue motor for sale.
jabba Offline
#3 Posted : Wednesday, 5 October 2005 5:09:39 PM(UTC)
jabba
I have a contact here in NZ who may be able to assist. Am just checking to see if he has the bits, and is happy to be posted here.
#4 Posted : Wednesday, 5 October 2005 6:10:25 PM(UTC)
Just buy a blue of black (pre VL) 253/308 dizzy and coil. It fits straight in, but on a red 308 you are best off not using the massive cap but using a points dizzy cap with an XD/XE Cleveland rotor button. You will also have to run a new wire from the ign
jabba Offline
#5 Posted : Wednesday, 5 October 2005 6:52:26 PM(UTC)
jabba
Try getting hold of Carl at the following address "[email protected]". He imports and sells a lot of bits through the trademe.co.nz website, and has a few pertronix ignition conversion kits about.
j
K
#6 Posted : Wednesday, 5 October 2005 10:14:43 PM(UTC)
Hi Byron,
What's the difference between a VK and VL V8 dizzy? I only ask because I don't know and I thought they were the same bar some advance curve differences...
Cheers...Dave
Edited by user Wednesday, 5 October 2005 10:31:28 PM(UTC)  | Reason: Not specified
#7 Posted : Wednesday, 5 October 2005 10:52:29 PM(UTC)
You nailed it. I should have said VL or ealier.
#8 Posted : Thursday, 6 October 2005 2:56:00 AM(UTC)
I thought you were thinking of the 6 cyl cars....
Cheers...Dave
Dylan Offline
#9 Posted : Thursday, 6 October 2005 3:59:08 AM(UTC)
Dylan
i have a large cap dizzy in my HQ (308) and it doesnt come close to hitting the firewall, i dont see any need to use a small cap on it. WB's had the same firewall and still use the big cap.
#10 Posted : Thursday, 6 October 2005 4:35:05 AM(UTC)
It doesn't hit the firewall on a red motor, but fouls on the vacuum 'tree' that the brakes, auto trans modulator etc connects to. It still fits, but only just and the brass tree limits how much you can spin the dizzy for advance adjustment. When you have
Munromad2004 Offline
#11 Posted : Thursday, 6 October 2005 6:28:11 AM(UTC)
Munromad2004
I fitted a standard cap to my GTS which has electronic ignition fitted and I found the standard holden rotor button fits just fine.
No problems at all. Maybe the XD ones are the same.
Dylan Offline
#12 Posted : Thursday, 6 October 2005 6:36:28 AM(UTC)
Dylan
maybe it just isnt a problem for me because i have the entire blue motor.
Guest (5)
