#1 Posted : Friday, 20 November 2009 4:36:34 AM(UTC)
Hi All ,Any info or comments on putting seats(front)in a HQ Holden van as Im considering putting some in but not sure on the laws of fitting them.IE:do they have to be HQ or alike ,can they be VT? VE? Ford? and what about anchoring points from a legal point of view,any info would be greatly appreciated as I have absolutely no idea in this area...jim
P.S. kidding about the Ford ones!
Jim in Adelaide
80569K Offline
#2 Posted : Friday, 20 November 2009 4:48:51 AM(UTC)
80569K
Try a trawl through the SA Transport Dept website, might give you a clue. The RTA in NSW has all that stuff online in memos to AUVIS and e-safety (pink slip) inspectors. If not give them a call, they should have an advice line.
Jvanner Offline
#3 Posted : Saturday, 21 November 2009 10:04:16 PM(UTC)
Jvanner
my mate just put VX SS into his HQ van. VT VX VZ im guessing they all bolt up the same. you cant use the eletrics but his hq seat frame bolted up to the VX seat with no mods to the frame
#4 Posted : Saturday, 21 November 2009 11:29:22 PM(UTC)
HI Jvanner thats wild,but what about regulations.If I can fit any seat in no problems,but Im wondering about anchorage points.You have half covered it they cant stop you if you use the same rails with no mods.
Jim in Adelaide
Absinth Offline
#5 Posted : Sunday, 22 November 2009 1:27:08 PM(UTC)
Absinth
If you bolt the seats in using the same anchorage points and original type bolts you dont need a modification plate or engineers inspection as you havent modified anything as long as you havent changed the seating capacity ie remove 3 seat bench and fit two buckets. If you have to drill new holes in the floor to mount the seats you need 3X3 inch square and 2mm thick washers added and then have it inspected and a mod plate fitted. This is Qld. compliance but I assume it would be the same in all States.
#6 Posted : Sunday, 22 November 2009 7:21:36 PM(UTC)
Not many vans/utes left with bench seats in?Is this something that is picked up on alot?I dont see all these cars having compliance plates on,that is why Ive asked this question.I do agree with you .I know somewhere there is regulations but I cant find any and spent hours looking for them.Thanks for the fitting advice thats what i will do.
Jim in Adelaide
Edited by user Sunday, 22 November 2009 7:23:37 PM(UTC)  | Reason: Not specified
Mr Void Offline
#7 Posted : Sunday, 22 November 2009 10:46:02 PM(UTC)
Mr Void
When I changed the Tonner fron bench to buckets (in QLD) I had to get a mod plate by an eng. Cost about $50 from memory?
Since I fitted WB seats into the factory anchor points (as Absinth said) there was no eng. cert. needed. (EDIT - my orig tag says 3seater - mod plate says 2seater)
Since then I have pulled the wb buckets and modded the rails on some Nissan Exa seats I got for $20... not sure if it is legal or not BUT the original anchor points are still being used and the mod plate is still there so Im hoping some fast talking will get me past any curious officers!
HTH
___________________
Why are you reading this, you should be looking up there^^
Edited by user Sunday, 22 November 2009 10:47:50 PM(UTC)  | Reason: Not specified
___________________
#8 Posted : Sunday, 22 November 2009 11:17:46 PM(UTC)
I have always been under the impression (for some reason?)that if you increased the seating it would need an eng mod because of seat belt anchorage.I will just put them in and see how it goes I suppose.
Jim in Adelaide
Mr Void Offline
#9 Posted : Monday, 23 November 2009 8:27:49 AM(UTC)
Mr Void
Well that makes good sense (unlike some of the road/vehicle rules!!). When I got the mod plate they did say that Id need it engineered if the original anchor points were NOT used. The inspection side of it only took 1min - he gave the seats a good shake and then looked under the ute to see where the bolts were coming through (while still on the side of the road) and then we went inside for me to pay...
The only reason I even drove it into the workshop was to have the plate fitted!
___________________
___________________
AGRO Offline
#10 Posted : Sunday, 9 May 2010 4:36:46 AM(UTC)
AGRO
Is it possible to fit WB Statesman seats onto HJ seat rails?
If so is it a straight bolt up fit, or is there modifications needed to be done as well as an engineers report?
75 HJ Sandman Pano
78 HZ BO6 Pano
#11 Posted : Sunday, 9 May 2010 5:51:57 AM(UTC)
straight on ,no need for a report ,i was told by a cop at a car show(for answering questions)you can go forward in seat years but not back,as long as you use the factory anchores.as in 1970 car fit '71 up 72,84,99 etc
AGRO Offline
#12 Posted : Sunday, 9 May 2010 6:29:20 AM(UTC)
AGRO
Thanks for that.
Now the job will be easier.
75 HJ Sandman Pano
78 HZ BO6 Pano
