#1 Posted : Monday, 10 October 2005 7:55:38 AM(UTC)
got a 64 eh special sedan with a worked 186, not sure exaclty wats bin dun to the motor, all i know is its got a mild cam and goes pretty well for a 6 lol. I bought it with a small ten inch thermo fan running at the front o the radiator, it had no mechanical fan running at the time. I bought a universal fitting mechanical fan and put that on aswell, so ive got 2 fans running on the radiator which is almost brand new. New thermostat and radiator hoses, timing seems good but still unsure y it is still reaching boiling point with normal driving around town, runs ok on the highway, sits on bout 190 degrees farenhiet wich is still hot i think. Any ideas for a cheap way out? i priced a 16 inch thermo and switch at ova 250 bucks which i think is rediculous, theres gota be an easier way out.. i hope.
ozjason Offline
#2 Posted : Monday, 10 October 2005 4:39:27 PM(UTC)
ozjason
You've obviously had the coolant out when you replaced the hoses, but have you given the rest of the system a good flush? You should be able to continually empty and fill the system - run for a bit each time it's full, just using water. (Last flush, put
bluHJ Offline
#3 Posted : Monday, 10 October 2005 4:53:27 PM(UTC)
bluHJ
Is the coolant actually getting too hot or is it just on the gauge. The temperature in the top tank can be measured with a thermometer. Can't remember exactly what though.
I had a mate years ago replaced everything in the cooling system before he f
