davewright Offline
#1 Posted : Thursday, 10 December 2009 4:04:28 AM(UTC)
davewright
Can anyone help me with these vin numbers im told its a factory 350 stato
10/71-bHQ16246S
81469QH708055
MODEL 81469QR
BODY 15215-S
TRIM1 327-10N
PAINT 567-13122
cheers dave
dave
dave
#2 Posted : Thursday, 10 December 2009 5:01:41 AM(UTC)
yep it is,barodo silver
#3 Posted : Thursday, 10 December 2009 7:23:10 AM(UTC)
Was thanked: 616 time(s) in 583 post(s)
Early HQ dont distinguish between 308 and 350, so all you can tell is its a Deville plus paint/trim.
davewright Offline
#4 Posted : Thursday, 10 December 2009 7:53:23 AM(UTC)
davewright
its got the turbo 400 and 350 block in the boot an 010 2 bolt mains, looks like the block has been a mooring block at hastings pier for the last 20 years
dave
dave
#5 Posted : Thursday, 10 December 2009 4:07:00 PM(UTC)
If it was a TH400 (ie 350) itll have the TH400 speedo cable entry into the firewall and the big uni diff yoke.
justgm Offline
#6 Posted : Thursday, 10 December 2009 5:48:58 PM(UTC)
justgm
carb linkage is another clue to it being 350 powered also engine bay wiring ( very long positive lead ) and p/s hoses ( long and cliped to front sway bar & sway bar also thicker , same as 253 & 308 GTS ) Hope this helps Mark.
#7 Posted : Friday, 11 December 2009 1:36:14 AM(UTC)
Byron roughly where would the speedo cable hole be ?,as Im about to put one in and want to get it close.
#8 Posted : Friday, 11 December 2009 4:07:17 AM(UTC)
Just look at a factory one, and then look at yours. There is a little dimple there to show you where to drill. 32mm holesaw does the trick.
#9 Posted : Friday, 11 December 2009 4:16:33 AM(UTC)
OK,Dont know anyone with one,Ill just have to guess ,I guess. :-)
OH durr Ive got one WB stato t400.kool thanxz Byron...no good cruise control...guessing again.! :-(
Edited by user Friday, 11 December 2009 6:59:51 AM(UTC)  | Reason: Not specified
#10 Posted : Friday, 11 December 2009 7:21:47 AM(UTC)
With the engine out look hard for a little indent on the firewall to the passengers side of the column.
#11 Posted : Friday, 11 December 2009 7:28:59 AM(UTC)
Thank you Byron,hopefully its on panel vans aswell,I think it would be.....cheers
