#1 Posted : Thursday, 3 February 2005 10:08:52 AM(UTC)
Have built a 351 windsor and having trouble finding the engine numbers. Any ideas where the are stamped on a 351 windsor
#2 Posted : Friday, 4 February 2005 9:25:14 PM(UTC)
The engine number should be stamped at the front behind the alternator, although alot of people mistake a 351 for a 302 and if that is the case its across the back behind the manifold. The other tricky thing is that if its a yanky one there will be no num
#3 Posted : Saturday, 5 February 2005 6:19:44 AM(UTC)
My American built Cleveland had a numeral only engine number stamped on the back of the block. Just above the left hand side cylinder head, I dont know if this helps you with a Windsor though.
#4 Posted : Saturday, 3 December 2005 4:58:55 PM(UTC)
its on the back same as cleveland
#5 Posted : Thursday, 8 December 2005 8:58:54 PM(UTC)
HI THERE DID U FIND ENG NO.?
IF ITS AN AUSSIE BLOCK CHECK UNDER ALT RUNNING VERTICLE BEHIND DIP STICK TUBE
This page was generated in 0.065 seconds.
