#1 Posted : Saturday, 15 October 2005 2:10:46 AM(UTC)
Hey all
I was just wondering if anyone knows if a wheel will fit a hx on the back that is 15x8 with a 3.5 inch back spacing, the wheels are centerline, any help would be great thanks.
trubluhq Offline
#2 Posted : Saturday, 15 October 2005 2:18:04 AM(UTC)
trubluhq
Daniel,
Apart from just size and back space...you need PCD. The distance between each wheel stud. Holdens vary PCD. The studs on basically siting on a circle of a set diameter. So the gap between each stud will differ from VT to VL to HQ/Z to HFTG etc.
#3 Posted : Saturday, 15 October 2005 2:39:57 AM(UTC)
HJ-HZ polycast wheels are 14x7 with approx 120mm back spacing are standard. 3.5 inch = 89mm, so by adding an inch (25.4mm) to the difference between 120mm and 89mm you get an additional 56.4mm of wheel offset over and above the polycast rim. Therefore I t
