Hey all I was just wondering if anyone knows if a wheel will fit a hx on the back that is 15x8 with a 3.5 inch back spacing, the wheels are centerline, any help would be great thanks.
Daniel,
Apart from just size and back space...you need PCD. The distance between each wheel stud. Holdens vary PCD. The studs on basically siting on a circle of a set diameter. So the gap between each stud will differ from VT to VL to HQ/Z to HFTG etc.
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
HJ-HZ polycast wheels are 14x7 with approx 120mm back spacing are standard. 3.5 inch = 89mm, so by adding an inch (25.4mm) to the difference between 120mm and 89mm you get an additional 56.4mm of wheel offset over and above the polycast rim. Therefore I t |
