WB UTE Offline
#1 Posted : Friday, 18 December 2009 5:35:32 AM(UTC)
WB UTE
hello all, I am having trouble with my WB ute. its been very reliable up until about a week ago.
it has a blue 202 and trimatic auto, very original 160,000 klm on the clock.
it is losing power going up hills and i cant accelerate past half pedal without it coughing and spluttering. it only does this under load. it doesnt miss a beat almost to the floor when it is in park.
i have changed plugs, cap, rotor and leads all made no difference.
any ideas would be great
thanks ted
bronsonHX Offline
#2 Posted : Friday, 18 December 2009 6:57:47 AM(UTC)
bronsonHX
thats what happens in my HX, i was told my 173 has the wrong inlet manifold/carby, off a 202 or 186..
#3 Posted : Friday, 18 December 2009 6:58:58 AM(UTC)
points under load?,qwick carby swap to check that.just ideas.
80569K Offline
#4 Posted : Friday, 18 December 2009 7:10:38 AM(UTC)
80569K
Fuel filter, accelerater pump, points, timing, condenser, coil, vacuum hoses.
WB UTE Offline
#5 Posted : Friday, 18 December 2009 5:32:07 PM(UTC)
WB UTE
thanks guys i will check a few of those and let you know how i go.
the wb has the original manifold and carby. i even changed out the original packard leads just in case.
fuel filter looks clean but i will change it just to be sure along with the points and condenser.
fingers crossed
#6 Posted : Friday, 18 December 2009 5:52:53 PM(UTC)
Another few to check on top of those mentioned above:
That the EGR valve on the outlet of the exhaust manifold isnt stuck closed;
That the auto choke isnt stuck on;
Make sure there isnt a "potato" in the exhaust (by potato I mean blockage, could be a collapsed muffler);
HEI dizzy module.
hx-sandman Offline
#7 Posted : Friday, 18 December 2009 8:18:09 PM(UTC)
hx-sandman
I had the same problem many years ago with a 202 WB. Tried everything with fuel, filters etc. Someone more technically minded may be able to decipher this but all it took was some sort of cream/lubricant on something electrical under the bonnet. That sounds like no help reading it back!
#8 Posted : Friday, 18 December 2009 9:42:31 PM(UTC)
Sounds like heat transfer compound on the HEI dizzy module.
#9 Posted : Saturday, 19 December 2009 9:32:15 PM(UTC)
HEI dizzys usually just stop in my experience(modules usually),this seems to be an intermittent problem.Going back to basics,you only need .fuel ,air and spark....air is relatively unavoidable,so its..fuel or spark.Im gonna guess change ..carby and dizzy..,this "WILL" tell you something.P.S. Give us all an update.
Edited by user Saturday, 19 December 2009 9:34:57 PM(UTC)  | Reason: Not specified
#10 Posted : Saturday, 19 December 2009 10:55:56 PM(UTC)
Agree Jim, my post wasnt re the problem, but in reference to the cream/lubricant HZ Sandman was referring to.
#11 Posted : Saturday, 19 December 2009 11:34:04 PM(UTC)
Byron ,as I have never heard of this cream, in your opinion is it kind of a fixer for some slightly bad designing?ps interpretted wrong by me AGAIN!lol
Utility8 Offline
#12 Posted : Saturday, 19 December 2009 11:56:42 PM(UTC)
Utility8
Recently, had an issue with a rebuilt distributor. Fitted VK injection set onto a red 202 using 12 port head & distributor from the complete VK black motor.
Distributor from VK Commodore got a complete rebuild prior to startup. Ran well for about a month. Problem surfaced with extreme pig rooting & not able to idle except at around 1200 RPM, but not much over that. Essentially, not drivable. Replaced EFI ECU to no avail. Contacted guy that rebuilt distributor to bench test for me. Found the problem, one small wire within the distributor was broken, but just making contact. (sorry, not sure of the wires purpose, possible module connection within distributor)
One suggestion was faulty module, but I thought the same as you Jim, module problem stops motor completely. But the wire connecting it appeared to be the issue. Sorted now.
If possible Ted, are you able to replace distributor with another one of known quantity? Then perhaps the coil to isolate the issue if all the other suggestions dont bring you any love.
Utility8
Edited by user Saturday, 19 December 2009 11:59:48 PM(UTC)  | Reason: Not specified
utility8
#13 Posted : Sunday, 20 December 2009 1:41:37 AM(UTC)
A bad connection anywhere in the engine firing but the not module itself,Anytime I suspect the dizzy or carby I just get a known good one at it tells me what the problem is usually.At various times Ive had three (modules)go ,all needed replaced ,but as said above and I said before replace dizzy and carby ,it will show something ,they always seem to.
Edited by user Sunday, 20 December 2009 1:46:20 AM(UTC)  | Reason: Not specified
#14 Posted : Sunday, 20 December 2009 2:53:27 AM(UTC)
Heat sink compound, used on power electronics to transfer heat to a heatsink. Im not saying that is what was described above, but that is what it sounds like to me (just read HX Sandmans comment above with this in mind). From memory you need to use this compound on some dizzy modules. I think I remember using it on the last Chev HEI I worked on (with in cap coil).
#15 Posted : Sunday, 20 December 2009 3:06:52 AM(UTC)
Thanks Byron.got 4 cars here thatll probably need that eventually.
petaus Offline
#16 Posted : Sunday, 20 December 2009 5:48:53 AM(UTC)
petaus
most of the times the module will just stop working all together, saying that i have seen a vk v8 that felt like it was running out of fuel, i play with the carby ended up i lifted up the module resealed it with new heat sink problem solved, also had a vk 6 that would not start undid the mounting screw retighten started a bad earth, if it has the varijet carb check the fuel filter in the carb it shelf it,s behind the big nut where the fuel line goes in, most just remove them.
let us know what you find, pete.
#17 Posted : Sunday, 20 December 2009 6:39:56 AM(UTC)
garaged78 Offline
#18 Posted : Sunday, 20 December 2009 8:16:46 PM(UTC)
garaged78
Hey fellas, just another idea to throw into the ring. I had a problem a few years back with similar symptoms and ended up finding out my carbon canister had broken down and was sucking fine pieces of carbon into the fuel line and clogging up the filter in the carby. Ended up needing to rebuild the carby to clean out all carbon pieces and bypassed the canister. No problems ever since. Hope that helps, and again, let us know the outcome. Cheers and a Merry Christmas to all.
hx-sandman Offline
#19 Posted : Sunday, 20 December 2009 8:19:11 PM(UTC)
hx-sandman
Okay - my issue was the module on the side of the distributor needed heat zinc grease and the problem was solved.
#20 Posted : Monday, 21 December 2009 6:40:25 AM(UTC)
I think WB UTEs problem will be the cone filter in the front of the Varajet carby, as petaus has described.
The white grease causing problems is one of the great urban myths. The grease itself is needed to transfer the heat from the ignition module to the diecast body of the distributor, but if it gets too hot the module will die & not recover.
The usual scenario is that people undo the 2 screws holding the module & lid, put new grease under the module, refit the lid & the engine fires into life again. All that has happened is that the earth to the module which is thru the hold-down screws has become faulty because it was corroded or the screws were loose. Removing & then refitting the screws has actually cured the problem by once again giving the module a good earth.
There are only 3 types of people in the world.
1. Those who make things happen.
2. Those who watch things happen.
3. Those who wonder what happened.
