#1 Posted : Tuesday, 5 January 2010 9:07:19 PM(UTC)
Morning Team
Ive picked up some gear off ebay for the G and I need to degrease it.
Can you please give some advice - the thing I worry the most about is the A/C compressor.
What's the best way to do this and not kill it?
Also a clutch fan hub which doesn't worry me as much.
#2 Posted : Tuesday, 5 January 2010 9:19:17 PM(UTC)
Petrol or degreaser ,but in small doses,maybe spray it on a rag and wipe it clean...just what I think.
#3 Posted : Tuesday, 5 January 2010 11:16:50 PM(UTC)
for the compressor, just go to bunnings or a clark rubber & get a couple of terminal plugs (look like rubber chair feet, but get the soft rubber ones) & utilux clamps, to clamp the rubbers over the pipe ends, then simply degrease as normal, as for the cluch fan it needs no special care, just a general degrease & hose off, but not high pressure..
also if the compressor has been left with the hoses cut/removed & the pipes unsealed, you may find it may need to be rebuilt, as even a small amount of dirt or dust can cause the seals to fail, once under pressure, I dont know if you can flush it out, youll have to chat with a knowlageable installer or A/C mechanic/fitter..
#4 Posted : Tuesday, 5 January 2010 11:25:40 PM(UTC)
degreaser is the best to use, i like monaro202s suggestion about the rubber ends to keep to crap out, ill have to remember that one
i wouldnt use petrol to clean stuff with
#5 Posted : Wednesday, 6 January 2010 12:08:25 AM(UTC)
Nice one
Thanks guys.
The lines all have masking tape over them, so I dont think therell be dirt in them, but Ill use your suggestion as I reckon thats a much better protection.
I doubt the masking tapes air tight, but it should have kept dust etc out.
#6 Posted : Wednesday, 6 January 2010 12:25:07 AM(UTC)
as soon as moisture gets in, its knackered
I innovate, never imitate..
Guest (5)
