#1 Posted : Wednesday, 6 January 2010 8:30:50 AM(UTC)
Evening all
Just doing some research into wiring of the VN cruise control into the HG.
I could get individual buttons etc. from Jaycar, but I would prefer to pick up a 3 push button switch set (Off/On, Resume/Accelerate, and Set/Coast) from an existing car (not necessarily a Holden).
Can anyone think of a car thats cruise works this way??
Edited by user Wednesday, 6 January 2010 5:33:16 PM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, 6 January 2010 9:00:04 AM(UTC)
VN are a latching on/off switch (ie push on, push off).
You could do it with 1 switch, 2 momentary pushbuttons (Set / Resume), and 2 LEDs.
edelbrock1 Offline
#3 Posted : Wednesday, 6 January 2010 11:07:55 PM(UTC)
edelbrock1
Forum Rank:: Member
Didnt VL have a single switch mounted on the dash somewhere that did all those things??
I remember driving home one day in my brothers VL playing with the thing. It kinda looked like a added on later item, but it was a Calais, so I thought it would have been factory.
From memory the switch was just above my left knee next to the steering column.
HTH
Edited by user Wednesday, 6 January 2010 11:08:52 PM(UTC)  | Reason: Not specified
#4 Posted : Thursday, 7 January 2010 12:42:31 AM(UTC)
Thanks Guys
I found that VL one this morning.
Looks to be good but without the light. That should work shouldnt it Mick??
Youre right about it looking a little aftermarket Edelbrock..
Anyone else have any other leads??
#5 Posted : Thursday, 7 January 2010 4:33:10 PM(UTC)
Not sure if the on/off switch is actually a latching one or not - if it is, then it will work, if not, youll need some sort of latching relay setup.
See either side of where "Cruise Control" is written on the switch bank? I think theres an LED in either side from memory, but Id have to check.
#6 Posted : Thursday, 7 January 2010 4:54:53 PM(UTC)
It also dpemds on how the unit is sired internally, I have used VN switches on an aftermarket unit, but the after market unit used one wire for up and down control with a 1 ohm resistor on the down button.
Warren
