gtrpu Offline
#1 Posted : Thursday, 7 January 2010 10:35:06 PM(UTC)
gtrpu
I need a pic ( or written description ) of what a pollution pipe on the drivers side of the inlet manifold of a 308 looks like. Its mounted about level with the back of the carby. There is a flat plate with 2 bolt holes in it and the pipe comes in at 90*, goes through the plate and then bends 180* and come back through the plate and exits again at 90*. I need to know what each end of the pipe is hooked up to????
Does one end have a flare nut on it that screws onto the auto choke?
Any help appreciated and thanks in advance.
#2 Posted : Friday, 8 January 2010 12:27:08 AM(UTC)
Was thanked: 616 time(s) in 583 post(s)
That is a HX-HX auto choke connection, not pollution pipes.
gtrpu Offline
#3 Posted : Friday, 8 January 2010 1:58:22 AM(UTC)
gtrpu
Thanks for that. So I guess the pipe that exits to the rear should have a flare nut on it to screw onto the choke bizzo.....where does the pipe that exits to the front end up?
#4 Posted : Friday, 8 January 2010 5:45:02 AM(UTC)
There should be 2 holes in the manifold plate.pipes go..front to front...back to back...and the other ends should have threaded flanges on them for the carby / chokey kinda thingy..
#5 Posted : Friday, 8 January 2010 6:29:06 AM(UTC)
From memory one of them has a hose on the end and goes to a vacuum port on the carb. The other goes to the auto choke threaded port. Ill see if I can find a picture of it. Which model? HX?
gtrpu Offline
#6 Posted : Friday, 8 January 2010 7:24:15 AM(UTC)
gtrpu
The 308 is out of a HX van and still has the Rochester carby.
#7 Posted : Friday, 8 January 2010 7:59:04 AM(UTC)
Oh Byron ,your right! one does have a rubber on,practising safe vaacum..lol
Jvanner Offline
#8 Posted : Saturday, 9 January 2010 12:56:49 AM(UTC)
Jvanner
what happened to the rest of the van?
gtrpu Offline
#9 Posted : Saturday, 9 January 2010 7:04:41 PM(UTC)
gtrpu
This......its being restored
#10 Posted : Saturday, 9 January 2010 7:41:58 PM(UTC)
Hi Mate,dont bog up the cowls,you will regret it!Lovely job though.
gtrpu Offline
#11 Posted : Saturday, 9 January 2010 8:37:47 PM(UTC)
gtrpu
Im not bogging them....thats how it came back from the sandblasters. Ive got a new cowl to be fitted once I start the body work. Plan is to get it driving, steering and stopping then do the body work. The body has been off the chassis and its painted underneath and the chassis has new "everything" in the brake, steering and suspension.
#12 Posted : Saturday, 9 January 2010 10:58:45 PM(UTC)
Glad to hear it,Good job.
