WB UTE Offline
#1 Posted : Sunday, 17 January 2010 8:53:44 AM(UTC)
WB UTE
does anyone know where you can get genuine HQ rally rims widened from the standard 6" to 8" /
i want to keep the rally II look but want wider tyres under the coupe
also any ideas on price
Edited by user Sunday, 17 January 2010 8:54:37 AM(UTC)  | Reason: Not specified
RdS Offline
#2 Posted : Sunday, 17 January 2010 12:20:06 PM(UTC)
RdS
i got it done here in melbourne.. cant remember the name off the top of my head, but a couple places do it as far as i know.
i payed 115 a rim to go from 14x6 to 15x7, but the price was same/similar to go 14/15" and a wide range of widths and offsets/backspaces. :)
4/76 HJ monaroGTS
4/76 HJ monaroGTS
adam PERTH Offline
#3 Posted : Sunday, 17 January 2010 12:41:53 PM(UTC)
adam PERTH
rare spares do a new pontiac rally 11 rim in 15 x 7 and 15 x 8 and 15 x 10.
looks very simular except the paint is different.
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
#4 Posted : Sunday, 17 January 2010 9:23:16 PM(UTC)
Adam is right, just get pontiac rims and if you need too you can sell the other ones ,or stash them until the price of them goes up even more stupidly than they are now,but they are still not too bad when you compare them to other rims,like centrelines for example,anyway the ponty rims are readily available and unaltered at the size you want.
HQforme Offline
#5 Posted : Monday, 18 January 2010 7:35:27 AM(UTC)
HQforme
Neale Wheels is Sydney do it. I was quoted $175 per rim for adding an extra inch to a 14x6.
"Silly modern cars"
"Silly modern cars"
Utility8 Offline
#6 Posted : Monday, 18 January 2010 6:28:56 PM(UTC)
Utility8
Ajax in Moorabin , Vic also do steel rim replacement.
Utility8
utility8
#7 Posted : Monday, 18 January 2010 8:47:27 PM(UTC)
If your game, do your own.
I have done a pair using ROH rims which you can buy from any place that sells steel mags, cost me $45 each rim, about 2 hours work, I have also just made up a slim line spare for a future project. All the GTS rim centres came from damaged rims, the most expensive was $15.
I will be adding a work guide on this subject on oldholdens holdapedia in the near future.
Kevin
GeeR Offline
#8 Posted : Tuesday, 19 January 2010 5:25:40 AM(UTC)
GeeR
My GTS rims are quite rough and corroded on the rim itself so Ive wondered about this, not to really widen just make them decent again. Interesting to hear that Neales do them ...
Ive started to think Ill just retire them and go to Rallye II ... has anyone bought them locally and what is the quality like? I assume no issue fitting the GMH caps and nuts (I again assume they were always the same as the Pontiac gear anyway)?
___________________________
WTB:
- HQ-Z standard rims
- HQ coupe front windscreen mouldings
- HQ ute antique brown trim - any pieces!
WTB:
- HQ-WB(?) bench seat 4-speed shifter
- HQ-WB ute rear window
- HQ-WB standard rims
- HQ-HX coupe front windscreen mouldings
- HQ-HX coupe door mouldings (the stainless one running along top of door exterior)
monarosteve Offline
#9 Posted : Tuesday, 19 January 2010 9:00:37 AM(UTC)
monarosteve
Neway wheels in West Heidelberg, Vic can do it for you,
http://www.newaywheelrepairs.com.au/
adam PERTH Offline
#10 Posted : Tuesday, 19 January 2010 10:33:16 AM(UTC)
adam PERTH
[quote]Originally posted by GeeR
the rally 11 pont roms are good quality. i think they are made by antique wheels USA.
i got mine with repo GTS holden centre caps which are impossible to steal and the angle lip 15" wchrome wheel trims for around $1300.
do the ,math, sell your avg cond rims for $400 (put toward rally rims) , save on sandblast and painting $300 and widing at $150 a corner = $1300
WANTED:
GeeR Offline
#11 Posted : Tuesday, 19 January 2010 9:57:25 PM(UTC)
GeeR
Thanks Adam,
Wheel Vintiques in the States do rallye II up to 16 X 7 or 8 and also in chrome. Always assumed that Antique Wheels here in Aus buy from them. I wonder?
Aside from weight, Id almost prefer a set of 16s in this more traditional style to the flash and pricey billet copies out there. I think the larger rim will also provide a better selection of tyres, particularly in a few years.
WTB:
WTB:
mackv8 Offline
#12 Posted : Wednesday, 20 January 2010 12:16:14 AM(UTC)
mackv8
The rally wheel fitted to hq gts and on and others. wrongly called THE GTS RIM is a Pontiac sports rally wheel. when Pontiac went from 14 inch to 15 inch in 1970 gmh got them, one of the reasons for the stud patten change. more rim sizes and type selection
I have a 15x7 Pontiac rally wheel as a spare for my one tonner as i dont want to put a 15x7 inch mag as a spare or a 14 x6 and have to comply to the 80 by 80 kilometer limit
yes i will swap it for a 15 x 7 rim that has the same dimensions it is in melbourne
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
80737k Offline
#13 Posted : Wednesday, 20 January 2010 9:39:31 PM(UTC)
80737k
Heres a thread i posted after getting my rims done at Neway with prices.
http://oldholden.com/node/79428
I DO NOT recomend anyone attempt to modify wheels themselves but this links a good read.
http://www.fordmuscle.co...06/02/Steelies/index.php
Fossil fuels are YUMMY !
HQforme Offline
#14 Posted : Thursday, 21 January 2010 7:05:14 AM(UTC)
HQforme
They look fantastic!
I have the same in 14x8 on mine, in black. They must be close to 5inch backspace, theyre so deep! Haha. I have centres of my caps black.
The tyre point is a valid one. Its increasingly hard to find wide 14inch tyres, and expensive.
In time ill be getting my centres turned into 15x8s, or maybe a little wider.
"Silly modern cars"
"Silly modern cars"
#15 Posted : Saturday, 23 January 2010 9:08:25 AM(UTC)
cheap start here...
http://cgi.ebay.com.au/R...ries?hash=item414c6d0022
Guest (15)
This page was generated in 0.102 seconds.
