#1 Posted : Tuesday, 25 October 2005 6:58:20 PM(UTC)
I have a Model A ford that has been rodded and I am trying to work out what model discs are on the front of it. I beleive they are around the XD ford era. Can anyone tell me what the studd pattern size is and if the discs from around Xy ford throught Xd are the same or have differences.
Paul351xb Offline
#2 Posted : Wednesday, 26 October 2005 7:59:00 AM(UTC)
Paul351xb
Stud pattern size for XY to XF is the same. It's the bearing hubs which are different in size. XY, XA and early XB have discs with the smaller bearing hub. Mid XB up to XC have discs with the larger bearing hub. That's why you can put later model wheel
#3 Posted : Thursday, 27 October 2005 2:18:16 AM(UTC)
Anyone know the PCD for ford stud pattern and the diamter of thehub tht sits in the centre of the wheel.
wayne Offline
#4 Posted : Thursday, 27 October 2005 2:19:33 AM(UTC)
wayne
an easy way to tell is to take your bearing numbers to a local bearing shop and have them matched they should be able to tell you what they are out of
other wise as paul said see your local wrecker
First
On
Race
Day
#5 Posted : Friday, 28 October 2005 9:24:35 PM(UTC)
Hello Glenn,
I was going to measure the centre spigot for you last night but I can't find my verniers. I'll borrow some from work and measure over the weekend.
As a pre curser though the XC onwards have the rotor and hub built as one unit & the
Edited by user Friday, 28 October 2005 9:25:34 PM(UTC)  | Reason: Not specified
#6 Posted : Saturday, 29 October 2005 1:30:48 AM(UTC)
Aren't Fords 5 x 114.5mm PCD?
One thing to be wary of with the Valiant hubs (if we are talking the same models...I'm a bit hazy on Valiant bits) is that the wheel studs on one side are RH thread and the other are LH thread.
Cheers...Dave
#7 Posted : Saturday, 29 October 2005 2:11:18 AM(UTC)
No Dave the Left hand threads were disconinued in 1970 along with the slant 6 at the end of the VF model run. The VG's kept the early (5 on 4") stud pattern but had RH threads all round & vented discs up front. I think from memory that you are spot on abo
#8 Posted : Saturday, 29 October 2005 3:08:53 AM(UTC)
Thanks Jim, I told you I was a bit hazy on the Valiant specifics... :-))
Cheers...Dave
#9 Posted : Monday, 31 October 2005 7:14:11 PM(UTC)
OK I measured up the spigot sizes on the weekend & came up with:
1/. Ford XW-XB 62mm (some XB's had the XC spigot size)
2/. Ford XC-EL & maybe later 70.5mm There was a change in rotor offset introduced with the EA
3/. Valiant/Centura 72mm
Th
#10 Posted : Saturday, 3 December 2005 9:47:57 PM(UTC)
hey all. I bought a set of jelly beans mags on ebay to suit the xc xd will these fit my 1972 vh charger stud pattern??
#11 Posted : Monday, 5 December 2005 7:42:47 PM(UTC)
Yes Mitch they will fit the Chargers stud pattern but you may have to get the centre hole enlarged by about a mm (see above posts about centre spigot size). You will also have to get new wheel nuts as the Falcons had bigger threads than the Valiant. No bi
#12 Posted : Friday, 9 December 2005 6:23:36 AM(UTC)
thanks for that jim. The mags are still not here :| i just wanna get them and chuck them on. i got the mags pretty cheep 200 bucks for 2 14/7 and 2 14/8 with brand new bfgoodrich 245/50 on back and 215/65 on the front :D, what ya recon about that?
Guest (8)
