GMH1975 Offline
#1 Posted : Friday, 4 November 2005 3:42:49 AM(UTC)
GMH1975
Hi all i have a HX sedan with a VN efi V8 setup and i am looking at fitting aircon to it.
I am thinking of using the set up out of a current model toyota camry(i work for toyota so parts are cheap).
I am not going to run a heater since the car is for summer driving basicly so i will try to itergrate it into the original HX heater box.
What i am after is some pics etc of of the factory mounts for the aircon pump and alternator and possibly some measurements so i can get one made up if need be.
Also i have noticed that the v6 holden engine has the aircon pump on the passenger side and was wondering if the mounts would fit on a V8?
Thanks in advance Christopher
Not the BLOODY Kingswood
#2 Posted : Friday, 4 November 2005 4:51:47 AM(UTC)
The V6 setup won't suit a V8 because of the oil pump & filter location on the LH front of the motor.
I would suggest an EFI setup, where the compressor is mounted down low on the driver's side of the block, and the bracket carries a tensioner as well.
GMH1975 Offline
#3 Posted : Friday, 4 November 2005 5:16:09 AM(UTC)
GMH1975
I was thinking of the VN V8 setup but according to a reply to a previous post on the subject someone has said that the VN setup hits the HQ-WB steering box which puts an end to that idea which is a shame because it would have made it a whole lot easier.
#4 Posted : Tuesday, 8 November 2005 8:59:24 PM(UTC)
I think the throttle body/intake ducting will foul the standard HQ-HZ alternator/aircond compressor mount. For a similar conversion, I made a new compressor mounting bracket based on a VT V8 Commodore alternator bracket and it seems to work well. This set
GMH1975 Offline
#5 Posted : Wednesday, 9 November 2005 4:54:16 AM(UTC)
GMH1975
HI Matt.
the intake does cause probs with a standard compressor mount.
The other problem i have is that i have the power steering pump on the drivers side which dosnt leave much room for the alternator.
i think my only option would be to use an har
#6 Posted : Thursday, 10 November 2005 7:22:57 PM(UTC)
If you are going to use a Harrop manifold, you will need to make up a 30-40mm spacer to go under the thermostat housing otherwise the top radiator hose will foul on the fuel rail.
You can still find the old Air International airconditioning units about t
This page was generated in 0.066 seconds.
