klompy Offline
#1 Posted : Monday, 22 February 2010 2:08:41 AM(UTC)
klompy
Hi how does the accessory function work in a hq.I cant find a 12 volt supply for my stereo anywhere.Does it exsist or is my switch faulty.Thanks Mike.
#2 Posted : Monday, 22 February 2010 2:26:23 AM(UTC)
it does exsist ,forward to you one step or away from off one step ,go to your fuses with a small light and try get it lite.
well mine has.
Edited by user Monday, 22 February 2010 6:30:22 AM(UTC)  | Reason: Not specified
#3 Posted : Monday, 22 February 2010 5:55:30 AM(UTC)
Ahh not all HQs had accessory on the ignition, it was standard in the prems & up, almost all kingswoods got it, but not all & on belmonts it was an option, best bet is to remove the dash base plate, undo the two screws holding the fuse panel in & drop the panel down, you will find on the back of the panel extra terminal points of which you have about 3 or 4 that are constant 12V. Make sure you fuse your supply lines....
#4 Posted : Monday, 22 February 2010 6:31:39 AM(UTC)
GOOD ADVICE ABOVE=====Make sure you fuse your supply lines....
#5 Posted : Monday, 22 February 2010 7:41:53 AM(UTC)
With all due respect, what a load of bullsh!t.
All Holdens since EH have had an accessory position. HQ onwards have issues with the steering lock mechanism worn & sometimes not selecting Acc or Start.
Trust me, they had all 5 positions (Acc, Lock, Off, On & Start) when they left the factory.
Holden usually wired wipers & heater fan etc thru the accessory switch contacts.
The vacant positions in the fuse box are for power windows , air cond & other less common accessories.
Dr Terry.
There are 3 types of people in the world.
1. Those who can count.
2. Those who cant.
klompy Offline
#6 Posted : Tuesday, 23 February 2010 3:29:05 AM(UTC)
klompy
Thanks Terry I will try my luck around the switch area.Mike.
klompy Offline
#7 Posted : Tuesday, 23 February 2010 3:45:06 AM(UTC)
klompy
Well just as Dr Terry said just needed to turn the key back toward me thru the off area.It is tight probaly from lack of use but does allow the wipers,heater and radio to work.Still cant beleive it was so simple.Thanks Dr Terry.
#8 Posted : Tuesday, 23 February 2010 4:02:16 AM(UTC)
didnt i already say this? :-)
#9 Posted : Tuesday, 23 February 2010 4:51:19 AM(UTC)
Dr Terry.
2. Those who cant.
Dr T.
I am sorry but I feel no respect with this comment. "what a load of bullsh!t."
If you wish to correct me please feel free to do so, I dont know all, i can only go on personal experience (of which I have come across more than 5 HQs without a accessorie position on the switch module, not even a terminal for it), but there is no need to be a smart arse!
I future I will not commect on anything with out your express writen approval..
klompy Offline
#10 Posted : Tuesday, 23 February 2010 5:22:14 AM(UTC)
klompy
Hi Jim yes you did but Dr Terrys explanation was easier to grasp,reading back now I get your explanation too.Thanks for the advice.Mike.
HQforme Offline
#11 Posted : Tuesday, 23 February 2010 6:54:00 AM(UTC)
HQforme
The sticky switch is a common ailment. I didnt know i had an accessory setting until it was pointed out to me!
Glad youve got it sorted mate.
"Silly modern cars"
"Silly modern cars"
#12 Posted : Tuesday, 23 February 2010 4:08:57 PM(UTC)
With any cars that are in doubt use the old fuse and toggle switch method.
D. A. Barnes Offline
#13 Posted : Saturday, 27 February 2010 2:06:41 AM(UTC)
D. A. Barnes
Dr Terry.
2. Those who cant.
Beautifully put. The correct way to stamp out myths is this way. There should be more of it.
This page was generated in 0.083 seconds.
