Keeo Offline
#1 Posted : Monday, 22 February 2010 7:31:17 AM(UTC)
Keeo
Does anyone know the reason why monaro gts sunvisors are different shape compared to sedans?
#2 Posted : Monday, 22 February 2010 7:34:47 AM(UTC)
Arent they the same as Premier & Brougham, but different to Kingswood & Belmont ?
Dr Terry.
There are 3 types of people in the world.
1. Those who can count.
2. Those who cant.
Keeo Offline
#3 Posted : Monday, 22 February 2010 8:04:18 AM(UTC)
Keeo
I dont know Dr Terry,my kingswood ones are rect
angles and the gts ones(ithink their gts hk) are rectagular with a notch in one corner and a small rod pokeing out .Was this a fancier setup for these models or did it have some other purpose?-keeo
#4 Posted : Monday, 22 February 2010 9:20:15 AM(UTC)
GTS get the luxury version sunvisors which are longer and swing right around and cover the whole side of you , and then clip into little clips that are screwed into the inner roof frame .
Brougham ones are essentially the same except the passenger side ones gets a Vanity Mirror .
Prem , kinga and Belmont are all the same "short type "
HK use Golf Ball Grain (except HK Brougham which uses the HT ribbed grain for some reason )
All HT use the ribbed grain .
HG all use the Roebuck Grain (except maybe some late commercials that may have swapped over to the ribbed grain after the intro of HQ , but i have nit seen one .
Classic Automotive Products will be making the HT ones shortly (long and short , but not brougham mirror type ) , the sheet plastic to make them is finished as is the die , its just a matter of making some frames . We will have Blue , Sandalwood and Black first . HG ones wont be that far away , and HK later in the year when that gets made . Its expensive to make them as each colour of each grain costs $8-10K to run the plastic alone .
www.monaromuscleparts.com
Edited by user Monday, 22 February 2010 9:25:28 AM(UTC)  | Reason: Not specified
PVS Offline
#5 Posted : Monday, 22 February 2010 9:25:21 AM(UTC)
PVS
Prem is same as King/Belly
I always assumed the Monaro ones are longer because the screen is wider at the top, and used in Brougham because they are fancier/more luxurious/better coverage
______________________________
Petsvetshop Discount Flea Treatment
PVS Offline
#6 Posted : Monday, 22 February 2010 9:26:40 AM(UTC)
PVS
beaten by a more accurate MMP
#7 Posted : Monday, 22 February 2010 6:03:44 PM(UTC)
Wider at the top ?
A Monaro front screen is slightly lower in height than the sedans, so it would be slightly narrower if anything.
2. Those who cant.
PVS Offline
#8 Posted : Monday, 22 February 2010 7:19:30 PM(UTC)
PVS
Wider at the top ?
Hi Terry,
Think about it, it would be wider.
