bundybluedog Offline
#1 Posted : Sunday, 28 February 2010 10:57:11 PM(UTC)
bundybluedog
how would you identify a GTR torana head and what is the diferance between a standard torana head.
justgm Offline
#2 Posted : Monday, 1 March 2010 12:29:05 AM(UTC)
justgm
Which GTR motor do you mean ? LC 161S , late LC 173S , LJ 202 ? Mark.
#3 Posted : Monday, 1 March 2010 4:57:35 AM(UTC)
bundybluedog
any info would be good, head numbers, which one is best? all is good
#4 Posted : Monday, 1 March 2010 10:43:51 PM(UTC)
To my knowledge all three GTR engines just used standard heads.
The LC GTR 161S had a 7438296 head.
The LC GTR 173S had a 2811929 head.
The LJ GTR 202 had a 2811930 head.
The best argument against democracy is a 5 minute conversation with the average voter.
#5 Posted : Tuesday, 2 March 2010 5:37:15 AM(UTC)
bundybluedog
thanks for that, i heard that they come out with larger valves?
Can you fit V8 valves to a holden 6 head?
#6 Posted : Tuesday, 2 March 2010 5:39:08 AM(UTC)
bundybluedog
so they were not a higher compression head?
#7 Posted : Tuesday, 2 March 2010 5:56:49 AM(UTC)
No, as I said they the were standard issue high compression head at the time. The only Holden 6 engine which had its compression lifted for a performance gain was the XU1. There are only 2 different sized combustion chambers across the entire range of Red/Blue/Black 6-cyl engines & all Holden did was fit the small chambered head to the larger engine. This lifted compression to 10:1 (~10.25 for the LJ).
Try & find a 2nd hand Yella Terra head or just go to a head shop & get yours modified to similar specs.
#8 Posted : Tuesday, 2 March 2010 6:04:27 AM(UTC)
bundybluedog
Thanks Dr terry, the reason i ask is im swapping some parts i have for some other parts and in it the guy said were 2 GTR heads. I was looking at turbo charging a 202 but now supercharging with a eaton M90 so i will be adding some larger valves ect just thought id gain some info on them first. i pick the parts up this week so ill check the numbers to see what they come off.
cheers Dan
