uctorana Offline
#1 Posted : Monday, 14 November 2005 11:23:46 PM(UTC)
uctorana
Hubby and I picked up a head for my uc. We were told it was a yella terra 186 stage 3. Can anyone help me identify the number that is on the head please...... 7429477 it also has E1 96 and then a #2 and a letter H.
#2 Posted : Tuesday, 15 November 2005 7:40:48 AM(UTC)
Hi uctorana.
The head you have is an HR 161 head casting. It may well be a Yella Terra head, but it is for 149/161/173 use. If you bolt it onto a 186 or 202 your compression will be well over 10:1, too high for pump fuel, even 98 octane.
Try & find
uctorana Offline
#3 Posted : Tuesday, 15 November 2005 6:06:14 PM(UTC)
uctorana
Hi Dr Terry
Thank you for your knowledge. But what I dont understand is that if you knew then why didnt the company that only deals with old holden not know that it is a 161 casting they told me it was a 186. I am glad that i checked up on the number
#4 Posted : Tuesday, 15 November 2005 6:11:51 PM(UTC)
I would also suggest not to use it, it would work, but you would have to be very careful how you drive (especially standard motor). Most of the time now, the blokes in the speedway industry use the 161 heads on their holden speedway cars! High compressi
Edited by user Tuesday, 15 November 2005 6:13:15 PM(UTC)  | Reason: Not specified
uctorana Offline
#5 Posted : Tuesday, 15 November 2005 6:22:47 PM(UTC)
uctorana
Thanks also for your input KeithHP-UC
I am just lucky that i checked the casting number and not just put it on the block. I just want to drive my UC again i miss driving her.
I will be contacting Dinkum and let know that the head is not as they hav
#6 Posted : Tuesday, 15 November 2005 7:15:32 PM(UTC)
There is a 202 you can use it on - an xM prefix ie a low compression engine. However I don't think this engine was available in a UC. Most likely it's an xL ie high comp engine.
uctorana Offline
#7 Posted : Tuesday, 15 November 2005 7:48:44 PM(UTC)
uctorana
So what is the casting number that i have to look for if I want to get a 186 head? thanks
uctorana Offline
#8 Posted : Tuesday, 15 November 2005 7:59:05 PM(UTC)
uctorana
I was also told that a 179 head will be ok on the 202 block just wondering what you guys think......
#9 Posted : Tuesday, 15 November 2005 10:48:06 PM(UTC)
Any 179, 186 or 202 head. Plus any low compression 149, 161 or 173 head. Just look for a red head with an L casting just above the manifold side next to no.5 or 6 cylinder. The head you have should have a H on it there (note that this is general and there
uctorana Offline
#10 Posted : Wednesday, 16 November 2005 12:29:42 AM(UTC)
uctorana
So if I put the 179 head on would I have to use 179 push rods and rockers? Or can I use 202 ones
#11 Posted : Wednesday, 16 November 2005 3:38:54 AM(UTC)
You need the early rockers and pushrods, unless you buy one of the conversion kits that allows you to use 138/173/202 rockers on an early head. I've got a head here that would suit you that has minor machine work done and has been modded to use adjustable
This page was generated in 0.120 seconds.
