ExportHolden Offline
#1 Posted : Tuesday, 9 March 2010 10:54:06 PM(UTC)
ExportHolden
My WB sat a bit low at the front when I bought it and now with the weight of the aircon compressor etc re-installed (thanks Dr Terry!)it is sitting even lower. Took the car for its first family outing over the weekend and it rode like a dray. The front springs have either sagged, are chopped or lowered springs. With only a casual examination they look like they were originally black and have been there a while. The back springs seem to be about the correct height.
The unladen static hub to guard measurement for the front is 360mm while a susp bloke I spoke to said it should be more like 400mm in std unladen trim.
I just want a standard set-up with a smooth ride, so must I install $150 new springs that are painted in groovy bright colours or can I just buy 2nd-hand original WB V8 (or HQ-WB V8?) springs and give 'em a wash and throw them in? (which I would prefer to do).
How can you tell that the 2nd hand springs are not stuffed? Is there a measurement for uninstalled std springs?
Thanks,
Phil.
#2 Posted : Tuesday, 9 March 2010 11:43:26 PM(UTC)
There probably is a measurement for standard spring length. I think if you go to the trouble of changing them you would be better off going for new ones. New springs and shocks and it should handle well.
#3 Posted : Wednesday, 10 March 2010 3:13:21 AM(UTC)
Aftermarket springs are much easier to fit as well! You need spring compressors for the originals.
gmholdman Offline
#4 Posted : Wednesday, 10 March 2010 8:24:29 AM(UTC)
gmholdman
I may be wrong but I think it is not so much the length of the spring but but the pounds per inch of travel. If you measure a heavy duty spring against a stock spring you will find the stock spring will be longer?? AL.
#5 Posted : Thursday, 11 March 2010 2:51:55 AM(UTC)
as Byron says....
its to do with spring width and tension,if they are too low,fit new ones from a reputable company,as its the type of job you only wanna do once!!
Edited by user Thursday, 11 March 2010 2:55:53 AM(UTC)  | Reason: Not specified
adam PERTH Offline
#6 Posted : Saturday, 20 March 2010 11:02:21 AM(UTC)
adam PERTH
this is the height of my WB stato @ 155,000 km.
maybe you just need a wheel alignment? cheaper - $70
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
Edited by user Saturday, 20 March 2010 11:04:29 AM(UTC)  | Reason: Not specified
ITCH Offline
#7 Posted : Saturday, 20 March 2010 11:18:03 AM(UTC)
ITCH
Hey comon Adam , re-size the pics u lazy prick ,,,,,,,,, hahaha
< Gotta Luv It!
<b><font color="orange">&lt; 4 SALE , SELLING .......SOLD!</b></font id="orange">
adam PERTH Offline
#8 Posted : Saturday, 20 March 2010 11:39:46 AM(UTC)
adam PERTH
how do i do that?.
thanks for the instruction of uploading pics - so easy even gen X can figure out.
WANTED:
Rhys Offline
#9 Posted : Sunday, 21 March 2010 12:56:47 AM(UTC)
Rhys
Thats a nice original looking WB Caprice Adam, looks like the previous owner really looked after it!
#10 Posted : Wednesday, 24 March 2010 3:06:17 AM(UTC)
ExportHolden
Mine sits a fair bit lower at the front than that.
Ive been going thru the Gregorys HJ manual (dont have one for WB, assume theyre pretty much the same?) and the replacement of front springs sounds a bit like rocket science. I think Ill need a spring compressor to get the original springs out, that seems pretty straight forward, as does getting the shocks out, but what else will I need to get the job done - especially the screwed expanding tool to expand the gap between the upper and lower ball joints to loosen the lower ball joint?
Guest (9)
