papaya hx Offline
#1 Posted : Tuesday, 16 March 2010 7:40:58 AM(UTC)
papaya hx
I have a 2/73 sydney built monaro gts4 and there is some questions over its originality because its vin starts with 8N69RCH------Q but its passenger side plate reads 80469QR. So my questions are
1/ When did they start making gts4s at the sydney plant
2/ when did they change the vin no from 8N69 to 8Q69 (the monaro story says early HQ Monaros had 8N69 vin nos)
3/ who can I give the numbers to to check either way
Thanks Ron
#2 Posted : Tuesday, 16 March 2010 7:48:34 AM(UTC)
Ron
All HQ GTS 4 doors are Kingswoods and hence they all have 80469 on the BODY plate. Early examples even have 8N69 as the start of the VIN. Release date is March 1973 so a 2/73 is not out of the question for an XV4 (special vehicle package code on Kingswood for GTS 4 door with 253 or 308). The TRIM code is the thing that will identify the car as a normal Kingswood or an XV4 optioned Kingswood. Kingswoods usually have a E trim code, and XV4 will end in W,X,Y or Z.
#3 Posted : Tuesday, 16 March 2010 7:51:40 AM(UTC)
80469 is just the code for V8 kingswood, which is what a 4 door GTS starts life as
not to many were made with 8N69 all were early 73
what is the trim code? it should end in X or Y (or maybe Z?)
sorry for the vauge answers, youll get a proper reply soon
papaya hx Offline
#4 Posted : Tuesday, 16 March 2010 8:37:00 AM(UTC)
papaya hx
30X and tangerine/lone o ranger stripes. Thanks again for help. Ron.
Mr.Jones Offline
#5 Posted : Wednesday, 17 March 2010 3:52:26 AM(UTC)
Mr.Jones
Feb 73 for Mar release
July 73 is the earliest 8Q69 I have recorded
As Byron has written the trim code is the clincher.
Leroy
"Planet earth is the asylum to which the rest of the universe sends its lunatics"
Voltaire
Voltaire
papaya hx Offline
#6 Posted : Wednesday, 17 March 2010 5:13:04 AM(UTC)
papaya hx
How accurate are Holdens records ? In the letter of authentisity from Holden the first line says
MODEL 1973 Holden HQ Kingswood sedan-(80369)
Engine 253c.i.(4146cc) 8 Cylinder-(L32)
Transmission 307:1 3 Speed Manual Transmission
So isnt a 80369 a 6 cylinder kingswood ?
Why does it then say on the next line it is a V8
The compliance plates say 80469 M20
What is the code for a 3 speed
The plates have never been off the car and I helped strip the body and took detailed photos of the blackouts which was the original paint.
So after all these years how can Holden say it is a 3 speed when the plates say 4 speed
can anyone shed some light on this subject Thanks Ron
#7 Posted : Wednesday, 17 March 2010 5:19:39 AM(UTC)
code for 3 speed manual is M15
standard motor/box for this car would have been 253/M20
belive your plates not the letter
#8 Posted : Wednesday, 17 March 2010 5:47:58 AM(UTC)
Ron
Just ignore the Holden letter. They always seem to be wrong. You are lucky they didnt tell you it was a low comp 253 (L33). It is possible the car is a mock up and they are actually telling you the truth, but very unlikely as what they have given you cannot be the case as a 369 is a 6cyl HQ Kingswood sedan which could not have had a 253 in it. Contact the Holden Monaro Register and you will get a much better and correct response.
On the same note, I recently sent Holden the VIN numbers off the 2 x 1972 Dandenong built HQ Kingswood utes with L30 engines (one of which was the Ewet). I am dying to see what they come back with, or would love to know what goes through the mind of the person who accesses the records when they see that both had 350 engines.
papaya hx Offline
#9 Posted : Wednesday, 17 March 2010 6:56:59 AM(UTC)
papaya hx
And I thought my HQ 308 4sp belmont ute was rare Ron
#10 Posted : Wednesday, 17 March 2010 5:41:34 PM(UTC)
They are pretty common in the scheme of things, although much less common than 308 4spd Kingswood ute. Both normally wearing a Sandman stickers and stripes though!
classic oz wreck Offline
#11 Posted : Wednesday, 17 March 2010 7:28:15 PM(UTC)
classic oz wreck
ive got a letter from holden telling me my ls 350 coupe is a gts 350 coupe...so not good records or research on holdens customer assistance in the scheme of things...
www.classicozwreck.com.au
#12 Posted : Wednesday, 17 March 2010 7:47:12 PM(UTC)
another tip that will help id a monaro, check for GTS badges..
hmmm..
papaya hx Offline
#13 Posted : Thursday, 18 March 2010 2:47:49 AM(UTC)
papaya hx
Ben is the man ! All is well. I dont know what Holden was reading but it cant have been my vin no. This is the second time ive had a problem with holden letters. The last time it only took 3 phone calls to them to sort it out. Thanks again for all the support & help especially to Ben Cheers Ron
monaro mark Offline
#14 Posted : Thursday, 18 March 2010 11:15:49 PM(UTC)
monaro mark
Byron, is the non Ewet 350 ute still alive?
Mark
[email protected]
#15 Posted : Friday, 19 March 2010 3:07:50 AM(UTC)
No idea. It was very close in build configuration and was sold by the same dealer who sold the Ewet.
80569K Offline
#16 Posted : Friday, 19 March 2010 5:42:23 AM(UTC)
80569K
I found D EWET.
Well OK, maybe not then, can I blame Google?
Reality is only an illusion which occurs due to a lack of alcohol.
Guest (6)
