#1 Posted : Thursday, 24 November 2005 8:08:08 AM(UTC)
Anybody out there got any advice on installing a/c into my HQ STATO. Was originally fitted to car but has been removed before I bought it. Car now has GTS dash with only two outlets. Is there any factory a/c units out there I could install, or will I have to fit an aftermarket under dash unit? Have been told this will cost approx $2,000. Sounds a bit too much to me. What do you think? Any advice on this topic would be very much appreciated.
#2 Posted : Thursday, 24 November 2005 11:17:41 AM(UTC)
Where are you? Depends what they pulled out. If the original behind dash piping and dash switch and cables and the air con heater box unit are still there all you need is the dash pad, but it depends what you already have.
Then you need a compressor(get
blwnhj Offline
#3 Posted : Friday, 25 November 2005 7:44:52 AM(UTC)
blwnhj
damien, i have aircon to suit your car. it has all wiring, hoses everything all underdash piping and the switch for it that you replace you standard heater swich with same size as far as im aware its the complete unit,
just get a re gas and ur done.
$20
BLWNHJ
#4 Posted : Friday, 25 November 2005 10:53:34 AM(UTC)
Not trying to cramp your sale but some of the behind dash ducting is not the same the Q dash is different shape, also the switch is a bit different you have to enlarge the hole a bit but it goes in. If you are looking to make it "original" you have to wat
blwnhj Offline
#5 Posted : Saturday, 26 November 2005 4:24:38 AM(UTC)
blwnhj
fir enough, i did not know that.
oh well have to keep trying i guess.!!!!
BLWNHJ
BLWNHJ
#6 Posted : Saturday, 26 November 2005 5:09:50 AM(UTC)
Thanks for your replies. Am gonna try and make it through the summer without air-con and see how my finances are next year. Thanks again for the offer. Cheers.
blwnhj Offline
#7 Posted : Saturday, 26 November 2005 6:58:50 AM(UTC)
blwnhj
i purposely took air con off. i dont think it all that great, u have four windows and being a statesman presumeably they are electric.
wind em down!
BLWNHJ
BLWNHJ
