HKPremier Offline
#1 Posted : Monday, 29 March 2010 5:30:44 AM(UTC)
HKPremier
Hi,
I was wondering does anyone know if a HT/G Sports dash will slot straight into a HK? If not is there a lot to do to make it fit?
Ben
My Cars
1968 HK Premier 186s Original
1968 HK Premier 307 Chev
Clambake Offline
#2 Posted : Monday, 29 March 2010 6:10:15 AM(UTC)
Clambake
You have to cut away some of the dash. Looking at where the 2 main gauges are, you have to cut semicircular slots into the dash metal for them to fit in
80569K Offline
#3 Posted : Monday, 29 March 2010 6:54:01 AM(UTC)
80569K
Dash wiring harness and intrument light harness is different.
HKPremier Offline
#4 Posted : Monday, 29 March 2010 7:17:14 AM(UTC)
HKPremier
Ok thanks. I was going to fill the ht dash with autometer gauges so the harness wouldnt matter anyway would it?
My Cars
80569K Offline
#5 Posted : Tuesday, 30 March 2010 8:43:52 AM(UTC)
80569K
Youll probably end up rewiring most of it anyway, unless you are very lucky and have completely unmolested harnesses. Get a colour copy of the wiring diagram and it might pay to talk to a gauge guru to see if you need to add any resistors etc.
Mick G Offline
#6 Posted : Sunday, 4 April 2010 7:10:49 PM(UTC)
Mick G
The differences I found were that HK gauge clusters had no earth(black)in their looms,where the HG loom had one.The HG looms had extra gauge lights(grey),but they all branch off the one wire anyway.All the wires in the HK loom go into a plug,the HG ones are all seperate.I hope this was helpful.Cheers,MickG
Water makes its own sauce
Water makes it's own sauce
#7 Posted : Sunday, 4 April 2010 7:26:30 PM(UTC)
Hi HKPremier,if you are going to fit autometer gauges in ,definitely get all the sensors/senders with them.Dash Lights are just + and - anyway to your exsisting light loom ,easy as,but the facia is the one to work on ,thatll be a little tricky.
