mark_23 Offline
#1 Posted : Monday, 29 March 2010 9:53:43 AM(UTC)
mark_23
Gday all,
Bleed the brakes on the HX today to get rid of all the old fluid, and was happy to find that it has had new rotors, machined drums new wheel cylinders and new pads all round and looks like a new master cylinder. Anyway there is a great pedal when the car isnt started but as soon as i start it the pedal moves towards the floor a heap, the brakes work great but you just have to push the pedal down heaps.. whats going on?
Mark
#2 Posted : Monday, 29 March 2010 10:24:04 AM(UTC)
itch = brakes plus..hahahhaha
CHEERSSSSSSSSSSS
mark_23 Offline
#3 Posted : Tuesday, 30 March 2010 1:57:07 AM(UTC)
mark_23
Ok itch spill the beans, whats going on with my brakes?
Mark
#4 Posted : Tuesday, 30 March 2010 3:07:23 AM(UTC)
brake booster?
#5 Posted : Tuesday, 30 March 2010 3:24:39 AM(UTC)
Mark
hahahaha, the only thing itch knows about brakes is when he BREAKS engines in 253 opps 308, damn, try again, 355 toranas..lol sniff snif, "KABOOOOOOOOOOOOOOOOMMMMMMM" parts strewn all over hahaha
thats a sure way of stopping our car, lunch the engine..hahhaa
FastEHHolden Offline
#6 Posted : Tuesday, 30 March 2010 3:41:11 AM(UTC)
FastEHHolden
I would be checking how much clearance the pushrod has on the piston of the master cylinder.
#7 Posted : Tuesday, 30 March 2010 3:42:12 AM(UTC)
FastEHHolden
has it always been like this?
#8 Posted : Tuesday, 30 March 2010 4:21:43 AM(UTC)
FastEHHolden hi, I think its the same answer,brake booster ,if hes got no vacuum leaks (including manifold)and has bled the brakes correctly it may be a good chance to be the booster.
ITCH Offline
#9 Posted : Tuesday, 30 March 2010 4:33:54 AM(UTC)
ITCH
I said that first (booster) but all the posts got deleted due to Clambakes BS
BTW thanks to the Mod that cleaned up that mess!!
CHEERS!!
< Gotta Luv It!
<b><font color="orange">&lt; 4 SALE , SELLING .......SOLD!</b></font id="orange">
#10 Posted : Tuesday, 30 March 2010 4:44:37 AM(UTC)
CHEERS!!
< Gotta Luv It!
sniff sniff, BOOM..lol
CHEEERRSSSSSSSS
ITCH Offline
#11 Posted : Tuesday, 30 March 2010 5:35:58 AM(UTC)
ITCH
sniffin glue, petrol and dope again WRECKED, tut tut tut!!
CHEERS!!
< Gotta Luv It!
mark_23 Offline
#12 Posted : Tuesday, 30 March 2010 6:16:23 AM(UTC)
mark_23
Its been like this for the whole week that i have owned the car LOL thats why i bleed them hoping that it would fix it, but it didnt.. and yes i did do it correctly... Im pretty sure there are no vacuum leakes but i will double check. so are boosters the sort of thing you can pull apart and fix or do i just get a new one?
Cheers Mark
ITCH Offline
#13 Posted : Tuesday, 30 March 2010 6:28:45 AM(UTC)
ITCH
I wouldnt pull apart a booster If ya dont know what ya doing, just take the booster and master cylinder to a reputable brake shop, they will test it and fix it. They may even have one on the shelf ready to go. I also advise to get the master re-sleeved and kitted while ya at it!
CHEERS!!
< Gotta Luv It!
#14 Posted : Tuesday, 30 March 2010 6:35:37 AM(UTC)
CHEERS!!
< Gotta Luv It!
told ya ITCH=BRAKES PLUS
wait till ya got a problem with ya door, it will be
ITCH=DOORS PLUS..
hahahaha
CHEEEERS
ITCH Offline
#15 Posted : Tuesday, 30 March 2010 6:47:36 AM(UTC)
ITCH
whats up WRECKED ? did I give bad advice to marko?
Doors ??, yep just slammed one in ya face!!
CHEERS !!
< Gotta Luv It!
#16 Posted : Tuesday, 30 March 2010 6:56:22 AM(UTC)
pffftttt@slammin door in my face.. you wish ya could haha
you did good advices to marko, im just annoyin ya, wantin you to fire up..
wait till ya check the "trunk" area of m HO out, im gunna slamm the "trunklid" on ya head, throw ya in the "trunk", and take ya for a chicago cab ride..LOLOL
CHEERSSSSSSSS
gee im funny,
ps, good advice to marko
Oily Offline
#17 Posted : Tuesday, 30 March 2010 7:16:38 AM(UTC)
Oily
Mark do you still have the problem? Something easily overlooked is that the handbrake cable is too tight before the rear brakes have been adjusted if this is the case the rear brakes are not getting adjusted properly. Once adjusted properly re bleed your brakes starting at the furthermost wheel first then if required reset the brake fail switch. Otherwise grab yourself some brake hose clamps and clamp off the brakes at each hose until you find the offending wheel. some times it can be as silly as a very loose wheel bearing."Word of warning" dont drive with the brake hose clamps on. cheers.
ITCH Offline
#18 Posted : Tuesday, 30 March 2010 7:29:08 AM(UTC)
ITCH
Oily , that wont happen , he said it only changes when the engine is running , that has to be 99% Booster problems ?? but yes I would do the rounds as you say like I said in my first post (Deleted)
CHEERS!!
< Gotta Luv It!
ITCH Offline
#19 Posted : Tuesday, 30 March 2010 7:38:25 AM(UTC)
ITCH
CHEERSSSSSSSS
gee im funny,
HAHA , I dont get fired up unless in the CAGE , and as for ya HO, I cant stand the smell of one never lone get in ya drug infested boot.......LOL
CHHHHHHEEEEEEEEEEEEEEEEERRRRRRRRRRSSSSSSSSSSSSSS!!
< Gotta Luv It!
mark_23 Offline
#20 Posted : Tuesday, 30 March 2010 8:11:17 AM(UTC)
mark_23
Wouldnt be the hand brake because that wasnt working until today, ITCH your first post must have been deleted before i got a chance to read it but ill look into the booster and see how i go.. one more problem on its way to being sorted, quite a few more to go LOL
Thanks, Mark
Guest (10)
This page was generated in 0.266 seconds.
