jayHK69 Offline
#1 Posted : Saturday, 3 April 2010 8:20:09 PM(UTC)
jayHK69
Just bought an AU11 Falcon and discovered there is no transmission
dipstick.
how do i check & top up the transmission fluid in it ?
jayson
Vintage Caravans Offline
#2 Posted : Sunday, 4 April 2010 6:20:05 AM(UTC)
Vintage Caravans
Same as a manual gearbox, raise the car, makine sure it is flat, then on the drivers side of the gearbox there is a bung to undo near the rear of teh gearbox body, fluid level should be at the level of the hole filled by the plug.
Remember to only use the correct Trans Fluid DO NOT USE DEXRON OR SIMILAR FLUIDS, it will stuff the gearbox. FORD removed the dipstick and filler tube around the EF/EL to stop people topping up with Dexron and other fluids thus destroying gearboxes
Matt
79 F100 XLT 351, 62 EK Wagon-327, 62 EK Ute-327, 62 EK Van-307 62 EK Sedan-202
Spot the odd one out??!!
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
jayHK69 Offline
#3 Posted : Sunday, 4 April 2010 7:06:17 AM(UTC)
jayHK69
thanks for that matt, do you happen to know the fluid type ?
jayson
bambino Offline
#4 Posted : Sunday, 4 April 2010 5:02:19 PM(UTC)
bambino
Castrol TQ95 or equivalent.
