jimmy Offline
#1 Posted : Sunday, 11 April 2010 10:01:01 PM(UTC)
jimmy
Iam currently thinking about upgrading the 302 in my xb coupe and am unsure on what to do. iam thinking of either putting in a 351 or a 460 in it. has anybody done this previously and what are your thoughts on it?
Paul351xb Offline
#2 Posted : Monday, 12 April 2010 3:57:32 AM(UTC)
Paul351xb
Honestly, DONT go the 460. Its a truck engine and it will just tear the coupe apart with the torque. If you want a pretzel instead of a car then go for it. Also you will need engineers certificates and in some States its now illegal to do. Go the 351 or if you want to be a bit different go the 400 cleveland if theyll allow it. 351 will be a lot easier to fit up though and work out cheaper to do with less hassels. With the money saved spend it making the clevo better.
Support female jelly wrestling. We can stop men going to war and solve world hunger all at the same time.
Marouk06 Offline
#3 Posted : Monday, 12 April 2010 7:25:33 PM(UTC)
Marouk06
IMO - the 460 coupe is one of the most brutal cars ive experienced. I loved and hated it in equal parts.In the 18 months a close mate owned his, among many others the most bizzare issue it created for itself was a split sill panel (along the seams..). It was coupled to toploader and literally tore itself apart despite significant strut/engine mount bracing and chassis connectors etc.
If you go that route - be concious of how hard this engine is on the body and over engineer every brace imaginable.
jimmy Offline
#4 Posted : Wednesday, 14 April 2010 11:27:39 PM(UTC)
jimmy
This is an interesting topic as i am gettin so many mixed reviews. if i am looking for a motor that can produce good horsepower say 500-600hp and has plenty of go in it to get it sideways what would be the best to take? cheers
Paul351xb Offline
#5 Posted : Thursday, 15 April 2010 4:27:54 AM(UTC)
Paul351xb
Jimmy, is the car going to be road registered? Is it going to be a daily driver? Do you mind killing a coupe shell through body twist? Do you want the car to be able to go around corners or just in a straight line? Before you begin, what sort of coupe is it you have? What was it from factory? The more you mod a coupe ( personalise it ) the more you can de-value it. Planning on keeping the car forever or selling it down the track? Theres more to consider here than just throwing in an engine.
Tex Scrotum rides again Offline
#6 Posted : Thursday, 15 April 2010 5:58:18 AM(UTC)
Why dont you just put a stroker kit in the 302,you can probably go all the way to 408cubes and there are no rego issues.
You also dont have to worry about the huge weight of a big block over the nose.
Over the last few years Ive looked at all the options for powering up my coupe and I keep coming back to a clevo(or windsor)stroker,it just seems to tick all the boxes,ie price,rego issues,easy to live with etc.
Pavetech are advertising a 434 clevor with 728hp for under 20grand,to me that seems great value.
Edited by user Thursday, 15 April 2010 5:59:40 AM(UTC)  | Reason: Not specified
Marouk06 Offline
#7 Posted : Friday, 16 April 2010 2:49:28 AM(UTC)
Marouk06
Youll pull the HP figures easy enough out of a stroker (or for that matter a 351 with supercharger).
Re getting it sideways - 500HP is easiliy 200HP more then you need in an old falcon, so wont be a problem. Diff ratios and tyre size are cheaper the 200HP if "show" power is all you want.
You can always be different - XR6 Turbo motors are very easy to push 500HP.
