80737k Offline
#1 Posted : Sunday, 4 December 2005 2:35:50 AM(UTC)
80737k
i'm new to this site, actually i'm new to computers. I was wondering if someone would take a look at my munro's numbers and I.d. it for me. Body; "HK80737-30123M" TRIM; "1153-14X" PAINT; "587-1764" . there isn't any INSERT number nor any TOP number. On the second (smaller) tag is "80737K J136855" and stamped into the firewall is "HK 30409M" Also on firewall directly underneath the "M" is another "M" stamped. I read the post titled "68 monaro info" by leith and byron rich's reply and i went lookies in the shed. my munro don't have ahump for the 10 bolt, speedo is under the booster, i have a shifter hump welded between x-member and seat mounts and looking for the bulge for a saginaw linkage, i dunno, there is a slight diffrence between left floor and right, but only slight , oh and drifting into my last post the steer box has "9D8" stamped on it. hope you can help, thanks.
Fossil fuels are YUMMY !
#2 Posted : Sunday, 4 December 2005 8:47:32 AM(UTC)
It's a Dandenong built HK GTS 186S. This is gleaned from the 80737, no 10-bolt hump and the speedo cable position. It could have been an Opel 4-speed or Powerglide auto.
All the numbers on the VIN plate and the chassis number on the firewall (complete
80737k Offline
#3 Posted : Sunday, 4 December 2005 9:36:57 AM(UTC)
80737k
thanks for your time, the original motor and box has been gone at least 17-18 years. would you know what i.d number i need to suit the car as i have a selection.
Edited by user Sunday, 4 December 2005 9:40:07 AM(UTC)  | Reason: Not specified
#4 Posted : Sunday, 4 December 2005 7:17:08 PM(UTC)
What ID number are you talking about
#5 Posted : Sunday, 4 December 2005 7:59:34 PM(UTC)
Hi Guys.
Byron, I think 80737k means an engine number to suit his body/chassis numbers.
80737k Offline
#6 Posted : Monday, 5 December 2005 12:25:18 AM(UTC)
80737k
g'day fellas, i gotta share the computer with 3 kids, the number i was on about was the steer box as byron said it's not the correct one , but since i have a choice of box's here, i could just have the correct steer box.
#7 Posted : Monday, 5 December 2005 1:13:47 AM(UTC)
4 of the 5 of the ones you listed before are NOT right for the car:
9D8 9/4/68 - too early.
21C8 21/3/68 - too early.
2F1 2/6/71 - way too late.
20M7 2/12/67 - way too early.
The one with 16.7 on it may be, but check for the date code in th
Edited by user Monday, 5 December 2005 1:14:45 AM(UTC)  | Reason: Not specified
80737k Offline
#8 Posted : Monday, 5 December 2005 1:40:30 AM(UTC)
80737k
yo ho, i'm back. Sent the kids with mum into town for icecream, that should buy me some time on 'ere. okay, my mistake here .. the box i said was "16.7" also as you asked has stamped "1KC" on it in the same spot as the others but this box is the only one
#9 Posted : Monday, 5 December 2005 4:11:52 AM(UTC)
Hi 80737k.
In the 1KC stamping, the C should be a numeral not a letter, could it be a 9 or a 0? In that case it reads 1st Oct '69 or 1st Oct '70. A bit late in either case.
Dr Terry.
80737k Offline
#10 Posted : Monday, 5 December 2005 4:32:11 AM(UTC)
80737k
G'day Doc, i just double checked but it can only be a C or a very neat half a zero or O. thanks for all the effort that you guys put into this.
#11 Posted : Monday, 5 December 2005 10:19:10 PM(UTC)
Get the box anyway as 16.7 boxes pull good money.
80737k Offline
#12 Posted : Monday, 5 December 2005 10:31:36 PM(UTC)
80737k
thanks byron, I already own all the boxes mentioned, just thought i'd find the one best to keep and will sell off the others. I'm amazed at the wealth of knowlege that flows from you fellas, but then until a few weeks ago, i didn't know people could insta
#13 Posted : Thursday, 8 December 2005 6:14:56 PM(UTC)
Your Monaro is a late September 1968 build. So you are looking for a steering box with something like 25J8 or 1K8. You may have to settle for a normal box, and get it rebuilt using the internals out of the 16.7:1 box you have, and then you can truthfully
80737k Offline
#14 Posted : Thursday, 8 December 2005 10:57:31 PM(UTC)
80737k
thanks byron.
Guest (7)
This page was generated in 0.066 seconds.
