#1 Posted : Sunday, 4 December 2005 3:02:54 AM(UTC)
G'day guys, can anybody tell me the compression allowable limits reading for my 186,( from New -to- Need replacement) in either PSI or Kpa, and also the max difference between each cylinder reading.. cheers jimbob..
#2 Posted : Sunday, 4 December 2005 7:13:46 AM(UTC)
Hi jimbob,
It is a long time since I had to do a compression check on a 186, but from memory the specs are 130 - 170 psi with less than 10% variance between cylinders.
Rebuilt time would be about 90 - 100 psi, IIRC.
Cheers...Dave
#3 Posted : Sunday, 4 December 2005 9:07:23 AM(UTC)
Just to add to the above, they are hot figures.
It may also pay to do a "wet" test after the dry one on any cylinder that is substantially down compared to the others, to see if the rings or the head/valves are worn.
To do a "wet" test, squirt som
#4 Posted : Monday, 5 December 2005 4:57:35 PM(UTC)
Thanks for the info Qute.. Did the compression test, the figures were good over all, 1-170 psi, 2-160 psi, 3-175 psi, 4-180 psi, 5-175 psi, 6-175 psi. Did a wet test on No 2, and the figures raised to 180 psi, so i suspect the rings are leaking slight
#5 Posted : Monday, 5 December 2005 10:09:05 PM(UTC)
You're welcome jimbob.
With numbers that high, I wouldn't worry too much about number 2 being down a bit and it is close to the 10% limit anyway.
The rocker adjustment CAN affect the results as can not having the throttle wide open too. If the rocke
#6 Posted : Tuesday, 6 December 2005 12:01:49 AM(UTC)
I am worried that the rockers are to tight, which might explain the rough idle and fuel consumption. The number of turns on each rocker nut is very different on each post to get down to 'no lash'(3-4 turns on some) , does this mean worn spring???, maybe
#7 Posted : Tuesday, 6 December 2005 12:10:13 AM(UTC)
You have a lot of compression - maybe you dont have enough carburation?? Could just need a good tune!
What are your motor specs?? Cam?? Headwork?? How long since it was rebuilt??
Generally the 1/4 of a turn rule works the treat wether new or old
#8 Posted : Tuesday, 6 December 2005 3:05:31 AM(UTC)
Keith, I don't know what the internals of the donk are.. got the engine from wreckers about a year ago and had problems ever since. We partially stripped and inspected for damage and wear before fitment but that was it. Maybe it should be lumpy on idle,
666 Offline
#9 Posted : Tuesday, 6 December 2005 3:24:38 AM(UTC)
666
Jimbob,
Maybe it was fitted with a mild Cam ?
You will need to fit a Degree wheel to determine this.
As Keith HP said you have heaps of Squeeze.
Maybe it was a mildly worked engine and will always run a bit lumpy (this will also mean slightly hi
666
#10 Posted : Tuesday, 6 December 2005 6:46:27 PM(UTC)
'Slightly higher fuel consumption'????? This car guzzles it, 350km from a 70 litre tank. Here's are question for you guy's, how do you identify what model head you have fitted, (part No , Features ???) Just curious... cheers jimbob
#11 Posted : Tuesday, 6 December 2005 9:18:40 PM(UTC)
Hi jimbob.
Casting number is the best to start with, near the LH (passenger's side) front.
Dr Terry.
#12 Posted : Wednesday, 7 December 2005 5:25:26 PM(UTC)
Ok, Dr Terry and everybody, I have done some searching around the engine and found the following part No's, Can anybody identify them and tell me if they are a match for a 186 fit or have I got the wrong parts fitted..
HEAD = 7438296 - (ho
