#1 Posted : Saturday, 8 May 2004 5:22:18 AM(UTC)
can any one have a ball park figure one gettings my 308 heads done to run staight gas(out of a hq)
#2 Posted : Sunday, 12 June 2005 8:22:23 AM(UTC)
Depends where you are. On the Central Coast I recently had my heads done on my VK 304 so it could run strait PULP If you pull the heads off yourself it will cost about $600 to $700 plus what ever the cost is to replace the carby for the gas unit.
trubluhq Offline
#3 Posted : Monday, 13 June 2005 3:46:55 AM(UTC)
trubluhq
Dion,
Ken is correct here. The mod they do to the heads is the same mod for running PULP or GAS. If you go to the attached page you can see the specs for a gas head yourself.
http://www.yellaterra.com.au/p9.html
The valves are bigger. Bloody sha
#4 Posted : Tuesday, 14 June 2005 12:36:46 AM(UTC)
I have some Yella Terra Stage 3 heads That i had reconed a year ago for my 308 on straight gas. I used them for about 3 t0 4 months weekend driving before i cracked a skirt off a piston.... New guides new springs and collets 3 angle valve joby stelite sea
#5 Posted : Tuesday, 14 June 2005 12:37:49 AM(UTC)
#6 Posted : Tuesday, 14 June 2005 12:38:19 AM(UTC)
trubluhq Offline
#7 Posted : Tuesday, 14 June 2005 2:41:22 AM(UTC)
trubluhq
Dion & Craig,
Stage 3 heads are OK with a modified donk. If Dion's 308 is standard with standard pistons he will have the same problem as you, a major rebuild. There may be piston to valve clearance issues. A Stage 3 isnt what he needs as I read it. H
