Keeo Offline
#1 Posted : Wednesday, 12 May 2010 5:47:29 AM(UTC)
Keeo
hktg s with saginaw 4 speedbox how does the return spring hook up?On autos and 3 speed manuals the spring(200 mm long and 20 dia)attaches to the end of lever and lefthand side (passenger)of gearbox crossmember.but with 4speed sag the spring runs smack into the gear selector . was there a different setup? or am i missing something.cheers --keeo
AMunro327 Offline
#2 Posted : Wednesday, 12 May 2010 6:22:00 PM(UTC)
AMunro327
One good thing about replying to questions on the Forum is that you learn about your own car. At least, I do.
My first thought was "what return spring?". Then I checked the good book and saw that there should be one. Saginaws have a different spring to everything else, but the book doesn't show where it should go.
From the photo below, I can only guess that the spring goes from the hole in the lever, just near the adjusting bolt (in line with the yolk in the photo) to the rectangular hole in the rear crossmember. Now I'd better searc around and find one for mine.
80569K Offline
#3 Posted : Wednesday, 12 May 2010 7:17:32 PM(UTC)
80569K
Have just scoured my parts book and found part #7449424 which is for the saginaw "LEVER, SPRING, EXTENSION - Hand brake intermediate", that's the only spring mentioned seperately for the saginaw cars. Rares don't stock it.
The GMH workshop manual doesn't show anything and the Gregory's #85 has a photo of a V8 4 speed hand brake setup and it is the same as AMunro327's ie, no spring.
Keeo Offline
#4 Posted : Thursday, 13 May 2010 5:46:57 AM(UTC)
Keeo
thanks for some answers.amunro327s picture is exactly what im talking about,i enjoy these old car mysteries .good to know there was something in the parts book thanks 80569k,strange how theres nothing in the manuals for a v8 4 speed handbrake setup.must have been word of mouth on the assembley line.--keeo
80569K Offline
#5 Posted : Thursday, 13 May 2010 6:56:43 AM(UTC)
80569K
Without checking, the handbrake adjustment is prob the same for all models, so no need to go too far with the diagrams. Just thinking that sometimes bit's go missing off cars because they might be a pain in the bum and make no difference to the operation, maybe said spring falls into that category.
Edited by user Thursday, 13 May 2010 7:05:39 AM(UTC)  | Reason: Not specified
AMunro327 Offline
#6 Posted : Thursday, 13 May 2010 7:46:44 AM(UTC)
AMunro327
Too true 80569K. That spring has been "missing" on mine for 16 years now.
Oily Offline
#7 Posted : Thursday, 13 May 2010 8:06:02 AM(UTC)
Oily
You have been a member since:: 28/03/2008(UTC)
Keeo I am thinking that HK's with saginaws have a handbrake relay arm similar to all HT's and HG's, if such the spring will possibly run from the hole in the arm rearwards to the floor, I think the hole in the boxed section where the front and rear floor pans join. the pic in the monaro workshop supplement shows the arm with the front of a spring in it but unfortunately that is all. Look under any HT or G should give you a clue if no more info comes to light. Oily
