Mqnaro Offline
#1 Posted : Saturday, 15 May 2010 7:28:15 PM(UTC)
Mqnaro
Does anyone know the easiest way to install a later model GTS dash into a hq.Is the only way to change the bottom of the bulk head so the later will fit to the original mounting points or is there another way?
#2 Posted : Saturday, 15 May 2010 7:38:11 PM(UTC)
Was thanked: 618 time(s) in 584 post(s)
Cut and remove the whole HQ dash steelwork and weld in HJ-WB steelwork.
#3 Posted : Saturday, 15 May 2010 7:38:20 PM(UTC)
Buy a hj- wb.
HZute-efi-VS5L Offline
#4 Posted : Saturday, 15 May 2010 9:48:31 PM(UTC)
HZute-efi-VS5L
As has been stated. Its a fairly large job. If you want everything to line up perfect.
You will have to go to the HJ-WB crash pad, glovebox, everything. May as well put in the HZ wiper switches also. Unless you want to run the HJ setup.
Your steering coloum will need the bottom platic cover changed also.
Jason
[url="http://www.stickthisdecals.com.au/"]www.stickthisdecals.com.au[/url]
#5 Posted : Saturday, 15 May 2010 9:54:43 PM(UTC)
also a wireing nightmare.
#6 Posted : Saturday, 15 May 2010 9:59:51 PM(UTC)
Jim, wiring is easy if you just use a HJ harness!
#7 Posted : Sunday, 16 May 2010 12:55:36 AM(UTC)
We'll see!(gts harness),dont forget to get all the proper senders for the gauges...lol
#8 Posted : Monday, 17 May 2010 2:33:19 AM(UTC)
HZute-efi-VS5L
make sure its the correct wire loom for your dash also. white is different to yellow looms etc etc.
#9 Posted : Monday, 17 May 2010 6:34:27 AM(UTC)
Originally posted by wbute
Buy a hj- wb.
i'm with wbute on this one, what a night mare!!
and for what? a worse looking dash!, there is no better dash than a HQ dash
#10 Posted : Monday, 17 May 2010 7:42:44 PM(UTC)
davequey74,me too!(nightmare)
Jim in Adelaide...WTB CENTER LINE AUTO DRAGS 15X7 UPTO 8.5 WIDE.
Edited by user Monday, 17 May 2010 7:44:04 PM(UTC)  | Reason: Not specified
Mqnaro Offline
#11 Posted : Tuesday, 18 May 2010 6:37:55 AM(UTC)
Mqnaro
thanks guys - what was I thinking? its ok Ill give myself un uppercut
Guest (5)
