65ehpv Offline
#1 Posted : Wednesday, 19 May 2010 9:53:58 PM(UTC)
65ehpv
G'Day,
Motor is out which gives me the oportunity to grab some numbers.
Rams horns
LHS 8932479 GMT
RHS 3855184 GM
Engine 350A18996 there is also T0612
Block 3956618
Intake 3927184
Fire wall HG05979 S (note that the S is very faint)
I'll have a look thru my HG parts book tonight, but thought i would consult the learned masses out there first
Carpe Diem
Carpe Diem
#2 Posted : Thursday, 20 May 2010 4:47:35 AM(UTC)
A few odd things there. Like a 350A engine number on a 618 block. Is it an original GTS350 auto? Should also have a H5 or H after the T0612. Manifold is right for a HT/G 350.
400bowtie Offline
#3 Posted : Thursday, 20 May 2010 5:49:21 AM(UTC)
400bowtie
Bryon , i'm working on a original 350 auto ht 618 block . i think autos 350 might have got the 2 bolt 618 blocks , i may be wrong throw
The difference between good and great is the extra effort
65ehpv Offline
#4 Posted : Thursday, 20 May 2010 6:32:08 AM(UTC)
65ehpv
Yes factor 350 GTS with 2 speed powerglide auto. I'll recheck all number tomorrow
Carpe Diem
Carpe Diem
#5 Posted : Friday, 21 May 2010 12:56:28 AM(UTC)
Most HT 350A were 3932388 or 3932386 and HG 350A 3932388 or 3970010. 3956618 were normally 4 bolt and in HG 350M applications. 2 bolt 3956618 did exist in 350A, just not very common. By the assembly date it's the right block though. The RH exhaust manifold is a HK-HT 307 & 1st type 327, hence the starter motor won't be original to the car. The LH manifold is right for HT-HQ 350 but the number is 3932479. All this info from the guru!
65ehpv Offline
#6 Posted : Friday, 21 May 2010 1:48:46 AM(UTC)
65ehpv
Thanks for the feedback Byron. Your information has now made me spend more money!
Carpe Diem
Carpe Diem
#7 Posted : Friday, 21 May 2010 2:49:34 AM(UTC)
Just to clarify its actually 3932473 not a 3932479 and 3855164 was also used on type 2 327 .
I have Never seen a 618 2 bolt block in HG but if they did it makes sense being the auto low horse equivalent in the US engines .
There is so few around to look at original now its good info to have . So John as i said i may be wrong about your engine , hence why giving info saying its gospel can be trouble .
If you have in fact got the right engine you have done well and its a bonus .
www.monaromuscleparts.com
This page was generated in 0.099 seconds.
