#1 Posted : Monday, 19 December 2005 11:04:31 PM(UTC)
hey guy's was wondering what i need too do too swap my hz ute over too a auto? apart from the changing the gear box itself, what else will i have too change/swap/replace? cheers
#2 Posted : Tuesday, 20 December 2005 12:03:58 AM(UTC)
Pedals (including accelerator if it is an electric kickdown Tri), shifter, Park/Neutral and Reversing Switches, Auto Radiator (or Trans Cooler), flex Plate instead of Flywheel. That's all I can think of at the moment.
Cheers...Dave
#3 Posted : Tuesday, 20 December 2005 4:10:12 AM(UTC)
You'll also need a console unless you wan't column shift, then you will need the column and column indicator as well plus the park/neutral and reversing switches on the column. You will also need to remove the clutch pedal. If it's a 6cyl you'll need to r
This page was generated in 0.103 seconds.
